Odarabla's infinite BS thread for the foreskinned (AKA Smack Down)
Your loss.
When the valves drop, right?
Thanks
I have a MWC turbo kmeber, UMI upper and lower A-arms, 2007 LQ9, WCCH ported ls3 heads and SDPC ported LS3 heads, LS3 intake, NW 92mm TB, NO 92mm plate kit, Jake's stage 4 4l80e, Moser 9", etc. etc.
Cool
I have heads/other backup motors. So please let me know if others are needed. I gotz dem hookupz. Not to mention other backyard motors to mess with Kevin Brewer's old *** as needed.
**** DENNIS!
Thanks
Cool
**** DENNIS!
7 Second Club
**** this thread sucks ***. I've PMed Jay about it.
PM me what you'd want on the 4l80e and some info..
There's a local Lq4 engine that has 36k or so on it, guy wants $700. Oil pan and intake are trashed but otherwise says it is good. Since I'm planning a 408, all I really need is the block and heads...but on that note, I could buy this, stud it, and run it for a while and save a bit of cash up and build when it blows/when I'm ready instead.
7 Second Club
Makes about as much sense as cam only.
Both can be a drastic change, so you are wrong.
You'd look good in a cavalier.
Wrong. A blower only forces air into your engine, that's it. A camshaft is essentially the "brain" of an engine. If you swap out a cam for a different cam, you are practically changing everything about that engine.
7 Second Club
Troof!
A blower changes the effective displacement of an engine. A cam doesn't.
I am back for a couple days and I noticed a video of a vette doing 3.99. So what do the furd guys post now when the modular vs lsx argument comes up.
*stirs the pot*
*stirs the pot*
*stirs the pot*
*stirs the pot*
So you are saying a cam is greater than FI? Lol gtfo a Supercharger changes everything about the engine. Hell turbos do to. Some engines run more efficient with turbos than with out. Forcing more air into the engine causes a lot more stress on the engine than any cam would be able to. A fair comparison would be cam swap vs cam swap not cam swap vs blower swap.
A blower does not change the dynamic compression of a motor. A cam does.
Do you think compression (whether it's static or dynamic) is a critical part of the motor? Be honest.
-Mark
