Street Racing & Kill Stories Basic Technical Questions & Advice
My Bolton lt1 vs stock ls1?
Old 10-03-2011, 01:42 PM
"I MAID THEESE"
Mavn's Avatar
Default My Bolton lt1 vs stock ls1?
I raced my friends stock, lid/catback ls1 from a dig and a 20 roll and both times I stayed with him. I actually pulled about a fender on the dig. Is this about right? They're both autos he has 3.23's and I do too. I have intake/cutout/longtubes/nitto 555 tires.
Old 10-03-2011, 02:46 PM
karpetcm's Avatar
Ya it does, at the lower speeds up to about 90-100mph you would keep up and then the LS1 should pull on you. At higher roll speeds the LS1 should pull like from 40-50+mph. Thats my experience atleast having both LT1 and LS1 cars and racing them. Even with all the mods a stock and well maintained LS1 pulls higher numbers at the wheel. I had a bit more mods then you on my past LT1 cars and highest i ever dynoed on a dynapack or dynojet was 274 rwhp, stock LS1 cars are usually going to be higher then that even for an auto but not by a whole lot. Just depends some LS1's dyno better then others as ive seen the numbers all over the place. Good run OP
Old 10-03-2011, 02:48 PM
"I MAID THEESE"
Mavn's Avatar
Thanks! Should I get a stall and 3.73s?
Old 10-03-2011, 03:20 PM
marc97taws6's Avatar
My old 97 WS6 did well for what it was from a dig with 555R's, full exhaust, 3.73's, and 3600 stall. Surprised quite a few bolt-on Ls1 drivers even
Old 10-03-2011, 03:43 PM
Amazin1's Avatar
i pulled an ls1 camaro with the mods i have in my Trans Am from 60-120 by about a car so, its not unheard of...and definitely a stall. made a big difference in my car. not sure if you'll notice a huge difference from 3:23 to 3:73...
Old 10-03-2011, 03:54 PM
turtle93's Avatar
I would think the bolt on's would let you pull a stock ls1 car
Old 10-03-2011, 06:09 PM
WSsick's Avatar
A stall in an auto car will make 100x the difference a set of gears would. That should no doubt be your next mod. You should put some distance between you and him then.
Old 10-03-2011, 06:36 PM
"I MAID THEESE"
Mavn's Avatar
Thanks guys!
Old 10-03-2011, 06:45 PM
gregrob's Avatar
Give the LS the same bolt ons and see what happens
Old 10-03-2011, 06:49 PM
ZFreie's Avatar
I hope your kidding lol
Old 10-04-2011, 01:18 AM
Fly on the wall's Avatar
Jesus, the LS1 is already starting off with
Much better flowing heads
1.6rrs
Better flowing intake
Better flowing exhaust manifolds
Thats just to name a few. Giving the LS1 the same bolt-ons argument is played out. To an LT1, the LS1 is already starting off with bolt-ons.
Put a stock LT4 against a LS1. Bet the LT4 wins more times than not.
Old 10-04-2011, 03:31 AM
Restricted User
z99ls1's Avatar
1.6rrs
Thats a lauph. Now your comparing a motor with a big cam in it. How bout you compare the lt4 to an ls6 than lol. Still the ls1 is a FAR better motor than either the lt1 or lt4. My first car was a 93 z28 so I'm not biased. Just stating the facts.
Old 10-04-2011, 03:41 AM
Restricted User
z99ls1's Avatar
All LS1's don't run the same and you can account for driver error. Going from a dig anything can happen. I have owned both lt1/ls1 and I can assure you ls1 is a completely different animal. My car bone stock would have put 3 cars on your car in the 1/4 mile and than pulled away hard up top. My friends bolt-on lt1 wasn't even close to my stock ls1 and than my friends cam/bolt-on lt1 couldn't run with me when I had a lid and cutout. When I had my cam/bolt-on z28 I was getting pulled by almost stock ls1's. Takes alot to get an lt1 running like the ls1. I know from personal experience. Now I also had a friend with a 383/cammed/bolt-on lt1 that gave a good suprise to alot of ls1's!
Old 10-04-2011, 04:04 AM
black_phoenix's Avatar
IMO, modded lt1's are no joke, but with stock restrictive manifolds, a4's with 2.73's run like turds from what ive seen
Old 10-04-2011, 10:01 AM
WSsick's Avatar
Who gives a ****? "What if" or "equal mod" discussions are retarded. The cars raced with what they had, we got a result, end of story. If the LS1 comes back with those mods, then it's fine to talk about it.
1.6rrs
I bet not.
Stock LS1 rockers are 1.7 btw, not 1.6.
Old 10-04-2011, 12:28 PM
Spec on a LT4 cam with 1.6s : lift 476/479 dur 203/210
2001 LS6 cam
207/217 int/exh @ 0.05" duration 0.525" / 0.525" int/exh lift 116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration 0.551" / 0.547" int/exh lift 117 LSA
Seems to be a good bit of difference.
Old 10-04-2011, 12:41 PM
I bet not.
I used to have an LT4 vette. I never ran up against a stock LS1 anything that out ran me at the track. I was running a consistant 13.0-13.15 @107-108. I am sure there are some stock LS1s that run better times but, like I said, more times than not.
Old 10-04-2011, 03:15 PM
FuryZ28's Avatar
LS1 > LT1 nuff said.
Old 10-04-2011, 03:23 PM
F-Body_4_Life's Avatar
Everyone knows that an LS1 will beat an LT1 if the mods are even. Seems like youre upset that the LT1 stayed with the LS1...
Old 10-04-2011, 05:46 PM
gregrob's Avatar
I am? My LT skull ***** LS cars regularly.
Quick Reply: My Bolton lt1 vs stock ls1?
