foxbody rape 5th gen AGAIN
I knew I would but there's a HUGE difference. I braked right after he started pulling but last night we went again and him giving me a 1 car advantage was a lot harder on him. He pulls me about a bus up top around 150-160mph but before that it's fair game. His clutch was slipping in 4th last night so he wasn't able to catch me on some runs but he made a new 40/60 meth mix with some octane booster and the car was running faster than ****.
I'm trying to get my tuning set and hopefully ill get a few more rwhp out of the tune but I never thought I would beat him. I just wanted to see how I would do.
That car is pretty much the king around here. Like I said he's taken out v10 r8s, alpha-6 gtrs, lambos, everything. One day though I will catch him
Maybe it's time to spray but since I got meth and boost spray would be catastrophic.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
BUT, I must say this, especially on the first vid it sounded like he was spraying a shot! A lot of guys with centrifugal units will wait until traction sets in and then spray a shot to get the revs up quick! Centri's love RPM, nitrous will get you them fast. I've seen it many, many times.
#32
Back in 01, we had a car were I was 'working' that made a bit over 1200rwhp... It had a blower... F-3R. It was a 434 and the 95 Mustang GTS it was in weighed 3350 lb and was tagged, etc. It ran a best of 8.25@169mph... on street legal tires. That said, the blower was ALL business and we saw upwards of 28 lb, which we all thought was astounding back then. Astounding that the engine didn't shatter...
Didn't the OP say the Mustang was 39x cubes? Could be mistaken, but if not I dont see a 390-cube motor with a good set of heads needing almost 30# of boost to make that number. Also, you have have to consider what blower he is running. So far I haven't heard much of the details on the build.
My guess would be he's closer to 18 lb boost in that power range, but the car doesn't actually make 750rwhp... That's BIG power, even today, for a street car. I kinda suspect it's not a 393 either. Maybe a 383, maybe a 408... could be anything between 351 and 434, but I'm guessing 408/10 because those have become very popular. Also, I still kinda do think the car has juice. My feeling is, it's a 600ish rwhp car. At 2800 lb, that's gonna run VERY quickly over a 1/4 mile(or even a mile).
I almost said last night, it reminded me of my own 408 Mustang, as it sounded VERY much like mine. I did the N/A thing, but built for juice. I'd like to know what size that engine is and frankly, to see pics of the under hood area... It's FAST, I know that! In fact, they reached speeds I'd no longer want to reach on the highway, even if it was an area with emergency crews standing by. Fox body Mustangs aren't good at holding the road at 140+mph.
#33
Only on stock suspension. Urethane bushing help a ton, and with stiffer springs and shocks, my fox was as stable as my C5 is. maybe more so.
On the size of the motor and power, there's really no telling. I think 750 is too high for that boost, but there's no telling what boost he really running, what sized power plant it is, etc... That said, I made 762 to the wheels at just shy of 15psi and that was with a 331. I'm proud of that number because even though I don't believe it's anything amazing, it's the stoutest number I've seen at that boost level. Anyway, a 393 built well would do that with a lot less boost - maybe around 10. Then again, I'm running a 76mm turbo, and it should be more efficient than a blower, which should need more boost to compensate.
#34
Now I see there's a little history here. OP said in the other thread that he's personally seen the car max out at 8 psi. So, I'm not discounting the possibility that it's making 750 to the wheel, but I think it's likely making less. They are awesome little cars, though, and 650 to the tire would be plenty to get that car into the high 130s. It could also be spraying. What does he use to tune that car? The MSD7531 box, or an up to date Big Stuff 3 with a driveshaft speed sensor would be able to control wheel spin to help it hook up on the street through the first few gears. That's the route I'm going with mine (BS3).
#35
Took to dyno
Car hit 440rwhp@2psi.
505@5psi
600@8psi
Reason I have different psi readings is the belt broke in half on the 2nd dyno run lol. Had to buy a new one and it was slipping when I hit 505rwhp. Finally got it solved and it hit 603rwhp.
This is on timing 19 very detuned.
505@5psi
600@8psi
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#36
All I can say is damn. It is going to cost you a lot more $ to beat him. You have to overcome the huge weight difference.
#37
There is no shot in it.
#38
#40
guy goes by 392bird on tccoa.
Bruce runs 10.5:1 and uses E85. when a 392 makes 600hp bwfore boost, it takes little to reach 750+ rwhp.
http://members.tccoa.com/392bird/ysi-idle.htm that is it at idle.
