Evangto87 (Boss 5.0) vs Beans (ZZR600)
the 65-150 ended actually around 140. Everything else in his descriptions were accurate. After 135, i start to pull back, but thats expected. Only race where we got up there was when he let off in the second 70 roll. I tached it out at 160 in that run even after he let off.
For everyone else, that run was on a slight downhill which is why the bike was able to get to 150 so easily. On flat ground from a 65mph start it would be a major struggle to be in front of the Boss at a true 150. By 120 he's stopping my pull, 130 starting to reel me in, and at 140+ i'm about to be in trouble.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
For a damn near stock car, the Boss is a very quick ride. 400+whp with a couple of basic bolt-ons is hugely impressive IMO.
That sounds like the smart move. The only way to know what it's really gonna trap is to take it to the strip. The problem a lot of people don't realize is that comparing numbers from two different tracks on two different days is not always going to give you a close idea of how things will go down on the street. And trying to figure out a car's exact trap by gauging a run with a bike (or vice versa) is just a bad idea. They perform very differently in a straight line, especially when you start throwing in different gears and different starting speeds.
I'm assuming you run at NED, which is a very solid track that typically gets people good timeslips, especially in cooler weather. I wouldn't say it's an Atco or MIR, but I'd definitely rather run there than LVD on the same day if I was shooting for the best times possible. I guess we'll find out once you get your new setup on the car and take it up.
Respectfully Evan, i disagree that we didn't get to 150 on that run. When i lifted my speedo was reading 165. It's off by 8-9% which would put us right around 150 real speed. Even watching the video you can tell that was the fastest run just by the speed the lines are whipping by.
For everyone else, that run was on a slight downhill which is why the bike was able to get to 150 so easily. On flat ground from a 65mph start it would be a major struggle to be in front of the Boss at a true 150. By 120 he's stopping my pull, 130 starting to reel me in, and at 140+ i'm about to be in trouble.![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Take it to the track before you mod up. Otherwise these runs to your comparison is bs. Just so ya know my bike and that bike make within 2HP of each other. That bike is not goin 126 w//o heavy mods.my bike could forsure go a bit faster than it did by taking the givi off and beating on the clutch but I would still expect it not to trapp over 120.
Just as a note: me and a bud ran my bike vs my car. Back then my car trapped 122 and it could beat up on my bike pretty good.
I'll know exactly what it runs on Sunday. I was planning to run an open exhaust but to keep it apples to apples i'll run the bike as is.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
EDIT: stock height and length with no strapping makes it even more difficult (in my mind more fun
You're heading to the track? Which one? PM me if you're going and I'll give you some pointers on launching that thing. The launch is by FAR the hardest part to get down on the bike and most people have absolutely no idea what they're doing (even most of them that think they do
). I highly recommend a rental or two when you get the opportunity to really tweak your skills and gauge improvement. It takes a LOT of runs to get comfortable and consistent launching a bike hard.
), but it's definitely the way to learn because if you can learn to launch it hard and consistently on a stock height/length bike with no strap, you'll be able to launch the ***** off it if you do lower/strap/stretch it (or ride a bike that is modded like that).
just watched a video of me racing the gto... god i miss that car sometimes. I need headers!!!!
My passenger is awesome lmao. I spun on the hit in this race... u just cant hear it because of the bike. The other bike was an older 1000 (trapped 132)
http://www.youtube.com/watch?v=r-sye...3&feature=plcp
#33
Made 525whp on the same dyno i was on. Weighs 27XX with him in it. In road course trim, he went 10.6 at 139.88. Trapped 106 in the 8th. His next pass, trapped 109 in the 8th but turbo cuppler popped off. Should have been a solid 140+ trap. Still only cutting high 1.7 60 fts. Its by no means a drag car. On the highway, its unreal. He last beat a new stock r1 raven. Good rider but heavy rider so hes looking for a slightly more legit race.
#34
found it..
http://www.youtube.com/watch?v=JdQo0...eature=channel
and this is 107 in the 8th. not 106
#35
It's pretty funny that i was substantially quicker than the R6s you raced when you had a 220lb passenger. That was a 40 roll right?
Had to have needed the rider mod.
#36
If u had to ask me... riding wasnt bad... it just seemed liek the bike didnt have enough steam. He was in it to win. Started at my quarter, pulled to my fender, then fell to my quarter again. 40-120. Both me and the passenger, who also rides... were in disbelief.
#37
Sounds like that RX-7 is retarded fast!
As far as the R6 race, he might have started in the wrong gear. That will have similar results to what you described.
Beans, good luck at the strip!
#38
#39
I have a 100% stock 07 zzr600 and my best to date was a 11.69@118.8X. That is at 2200 altitude and probably 195lb rider when fully geared. Most runs were 11.7-11.8@117-118
#40
