Street Racing & Kill Stories Basic Technical Questions & Advice
Pullied eaton vs KB 2.1 2valve
Old 04-09-2012, 11:00 AM
badblazeSS's Avatar
Default Pullied eaton vs KB 2.1 2valve
Little easter run 1 of 2. First was from 20roll 03 cobra spins 98gt wins by 2cars. Second run(not on vid) 35roll 98gt clutch slippage 03 cobra wins by 2 cars. Both on 14lbs. Good runs
http://www.youtube.com/watch?v=AaQGi...1&feature=plcp
Old 04-09-2012, 11:40 AM
99peweterls1's Avatar
Not a bad running 2valve. My money is on the termi though.
HioSSilver's Avatar
Now we have 2v outrunning 4v on the same amount of boost.......what's the extra valves for?
Old 04-09-2012, 11:53 AM
2SSARME's Avatar
lololol uh ohhhh
Old 04-09-2012, 12:08 PM
ohioborn80's Avatar
Good runs. Like to see a race with each not having issues.
Old 04-09-2012, 12:14 PM
Heater's Avatar
On the street anything can happen...I think I read that on here
Old 04-09-2012, 01:03 PM
badblazeSS's Avatar
eaton made 460hp 2valve made 498hp
Old 04-09-2012, 02:16 PM
Mach Boy's Avatar
More weight on that Termi too.
Old 04-09-2012, 04:19 PM
registered user
ScreaminRedZ's Avatar
The boost might be the same, but that KB is going to be a lot more efficient than the Eaton on the Cobra.
Old 04-09-2012, 04:50 PM
HioSSilver's Avatar
I could understand that if they were both 4v motors. But I would think the flow of the 4v head would out do the 2v stuff even with the eaton.
Old 04-09-2012, 05:21 PM
registered user
It is possible that a alot of that difference is from the KB being easier to turn and the solid axle of the GT might eat up less power than the Cobra's IRS. Just spitballing ideas.
Old 04-09-2012, 06:43 PM
I'd like to see a roll
Old 04-09-2012, 08:41 PM
HioSSilver's Avatar
Could be. The t65 probably eats up a bit more power than the 5m too.
Old 04-09-2012, 10:23 PM
FlatBlackZ28's Avatar
There could be other mods too. Does the 2v have head work or aftermarket cams?
Old 04-10-2012, 02:12 AM
badblazeSS's Avatar
forged Sherlock. Stock heads and cans.
Old 04-10-2012, 09:16 AM
registered user
Damn you, autocorrect.
Old 04-10-2012, 11:23 AM
automach1's Avatar
Don't be dumb
Old 04-10-2012, 12:05 PM
HioSSilver's Avatar
Just stating the obvious at this point. Automach should be building a 2v!!
Old 04-10-2012, 12:31 PM
Heater's Avatar
2V's are taking over SR&KS forum
Old 04-10-2012, 02:26 PM
There will be a few vids of a nearly 600rwhp 2v and an LT1 around the same power level (both are DD's and are on pump gas and LT1 with stock heads) as we hit summer time. Not that they are anything record breaking, but peoples heads are sure to explode around here when some big dogs start falling, given all the 2V/LT1 hate.
Quick Reply: Pullied eaton vs KB 2.1 2valve
