Got Killed by a Twin Turbo 350z
#41
!LS1 11 Second Club
Originally Posted by bLuE11secTA
hey guys i own this 350z you all are talking about and im indeed running 6psi total so each turbo is putting 3psi . the car did dyno 372 running pig rich! jus so you know im an ls1 guy myself i recently sold my ls1. i did not expect the 350z to move the way its moving but hey im not complaining. hugger ss did the whole install on the car. im going to be tunning the car for at least 9psi . at 8.5 psi these cars are putting down 450rwhp 430 rwtq. and i have not spent the kind of money you are thinking ive put in about 7k thats it.
As for the amount of $$$ you spend on your car, that's your own business. Anyone who criticizes the way you spend your money on your car is not worth the effort of arguing with them, just show them your tail lights in response.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#42
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Secret](https://ls1tech.com/forums/images/smilies3/secret2.gif)
Originally Posted by Hugger SS
you let off before we hit the sweet spot
![Violen](https://ls1tech.com/forums/images/smilies2/violen.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#43
Most places sell the kit for 5700...with the BOV and some other minor things...came to 6k
#44
wow, hugger... 10/11 post in a row are yours!!! You can just copy and paste the quotes and use the correct tags... or just say who you are talking too... no need to ***** like that... thats my job
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#48
Originally Posted by Drew98TA
I ran my friends twin turbo 350z and all i have to say is...
DAMN, that car moved. We went from a 30 roll and it was pretty even until about third, he started to pull away, once we got into fourth (my gearing, think he was even in 5th by that time) he put 2 cars on me when I shut down around 115-120. He put down 370rwhp on 4-5lbs of boost. Was running 6lbs tonight and will get tuned for 9lbs. That is going to be a sick car.
Since i'm posting a loss, here's another one from tonight. Ran my buddies second gen talon, got pulled by 2 cars again, letting off at 120 or so. (i stop myself from going any faster and have made a pact to stay out of 5th)
Start from a 50 punch with him brake boosting. I pulled out a car or so infront, about the time i'm going into forth he starts reeling me in, passes me pretty hard around 110 and puts 2 cars on me.
Second gen talon, 50trim turbo, cams, 20lbs of boost on c16, and other misc stuff. Obviously we've got some quick imports down here. There weren't any domestics to play with tonight.
I did beat my friends WRX which is also a 12 second car. lol. I love these guys. They definatly have my respect.
If your curious as to what i have...
Important stuff- LT's, ORY, Borla, Lid,FTRA, Jantzer TB, pro 5.0, nitto's. Not to shabby but far from real fast.
Thanks for readin my glorious deaths.
Drew
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
Drew
#49
wha?
did you just say that any turbo motor, set up right, will always beat a n/a motor? i think you might want to take back that statement, or at least rephrase it. i don't think that, for instance, a turbo beetle could beat a properly set up and properly driven ls1, unless god himself was behind the wheel of the bug.
turbos are not magical. they are mechanical. they obey the laws of physics. they just put more oxygen into the combustion chambers. there are many different ways to do that, turbos, nitrous oxide, superchargers, hell even ported heads and more agressive cams will do it.
#50
hey is you 350z white? were you at sonic off nacodoches that night? a guy that i work with said he saw this white 350 z at sonic and went out to race and flew past everyone. just wondering if you are the same guy he was talking about
#52
STF veteran / 10 second club
http://www.greddy.com/page.asp?idx=7
GReddy's twin turbo project car .... 370fwhp ... 33x rwhp.
High 12 second quarters ...
Car looks nice at least ...
#53
STF Veteran
Originally Posted by Skarecrow
wha?
#55
Originally Posted by 99-LS1-SS
I think he meant two motors that are the same size except one has a turbo and one is built N/A.
i'm still not entirely sure what he means. if he means that if you take a n/a engine, put a turbo on it and then properly tune it, the turbo-equiped version is gonna make more power... well that is just common sense. in fact it's so obvious, that it's not worth mentioning... so i'm not sure why he would say it. thus i don't think that's what he's saying.
if her perhaps means something along the lines of...
[engage benchracing mode]
take a stock ls1, person A puts a turbo setup on it and does nothing else, and person B goes all out with the n/a route... that person A is going to make more power in the end... i'm still not sure that's true. what's the maximum boost you can run, on pump gas, on a stock ls1? due to it's naturally high compression, maybe 10-11 intercooled psi, with excellent tuning? what's that equal, about 400-450rwhp (i really do not know)? you can get 400-450rwhp out of a an agressive cam/heads package, although i dare say the turbo engine would have more power under the curve most likely. BUT once you get into stroker packages for the ls1 engine, the n/a ls1 can equal the turbo ls1 in power under the curve, and best it in top end power, all the while still on pump gas.
this of course begs the question "why does the turbo ls1 have to remain stock?"... because, if you mod the turbo engine to the same extent you've modded the n/a engine, you get back to the "why are we even having this discussion, it's common sense" paragraph i posted at the top.
[benchracing off]
#58
It's pretty damn impressive to be putting down 372whp with only 6psi.
#59
Originally Posted by ls1320
Yea I watched a 350z get dynoed at Conley's. At 10psi it made 442rwhp and 480ftlb of torque, very impressive I must say.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
