LT1 killed by a 2V??
#61
You can go back threw the threads and find it....or ask him. You even said in that thread he pulled you so hard you thought he had a cam.
If you want to compare times he has already outrun you at the track....12.2@114> your 12.6@108....quit talking out your ***.
I'm not saying he has run faster than me. He ran 12.2 and I ran 12.56 with only 2 runs. What I'm pointing out is he has full bolt ons, cam, and has a built motor.
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#62
The 2V PI heads were 99-04. I had a 03 GT with under drive,prof.products tb,elbow&spacer,Xpipe,Mack cat back,spec stage 2 and 3.73's. The car ran 13.2's all day on 315/35/17 street tire and 12.70's on et streets. First through third felt good in the car but felt like it lost its get up go in 4th.
Not defending the mustangs but if that's a head and cam Stang and running 13's something is wrong.
I own a 02 M6 NBM formula now,can't beat it for power and gas. But I did enjoy the sound of the Stang rolling through the gears.
#63
***Repost Police***
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
99-04 was all PI, the major mechanical change they did in mid '01 was going from the T45 to the 3650 (manual transmission).
#64
Mid year 01 they went from the T45 trans to the 3560 trans. But as for the PI motors they started in 99. I have a friend that has a 99 with the ON3 turbo kit. Car is bone stock except for turbo and exhaust. On 8 or 9lbs it made 502whp.
#66
Yea, with 40rwhp advantage I knew he was full bolt ons. The cam statement was a joke towards him, but I'm not surprised you would try to twist things around.
What's even better is you are comparing that car to a Mach 1 with nothing but gears, ram air intake, and catback. ![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
The lt don't even have full bolt-on's (see where you twisted again) and the one's he has are not great. A rebuilt motor, not even bored with 2 used stock pistons from another motor is a "built" motor(you twisted once again) to you....lol
You always play your mods down and everyone else's up.
#67
You guys want to see something interesting? Here's an old article in MM&FF with a bunch of HEAVILY modded Two-Valve Mustangs. Look at the times they run. These cars have every bolt-on imaginable, Ported heads, Ported intakes, Cams, super-short gearing, full suspensions, heavy weight reduction, slicks/skinnies, and most importantly, seasoned drag racers behind the wheel. And are hard pressed to get in the low 12's. Without a good head like TFS, a N/A 2V won't keep up with the competition. That's been my experience with them at least. Stock for stock, bolt-on for bolt-ons PI GT vs. LT1 is close race BUT, once you get into the internal mods, it's not even close. 2V is gonna need Forced Induction to play.
Here is that article.
http://www.musclemustangfastfords.co...t/viewall.html
#69
You said it. I don't twist ****. Apparently he yanked you pretty hard.
You are talking down the LT1 but talking up my Mach 1.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
You say he put in 2 stock pistons. He's been inside his motor, no telling what was done. Prolly about as "bolt on" as your LS6. BTW my 302 that made 456 to the tires is a stock motor with replaced stock pistons too.
#70
I don't think you broke new ground there. Pretty much everything you said everyone here has known... 350cid vs 281cid, both have shitty parts to start with but once you put good parts on...duh at who has more potential.
#71
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#72
#73
He pulled pretty good when I was spinning on worn 275 Raptor street tires, yep. Like I said, he had 40rwhp over me there should be no surprise there. I beat him where it counted though, the track.
Hell you've called my Mach 1 with gears, pvc intake, and catback "heavily modded".
#80
