Death to HioSSiver!!
#62
I know the feeling man. When I was putting my car back together and my girl was about to have our daughter I kept having all sorts of issues with my build. Remember I had a brand new block that had a crack in it? Not only that but I had to shell out more $$$ for a new block, gaskets and machine work. The new block was $1200.00, gasket kit for my motor, $400.00, new freeze plugs, $70.00, machine work $600.00, New rings, $400.00.. Then I didn't have the time to work on it and I couldn't leave the car at my buddies shop so I had another friend pull the motor for me for $700.00. This was to pull and reinstall.
#63
#64
Triangle Speed Shop makes the most expensive, and Melling makes the gears where you just replace them and keep the stock housing.
Stay away from MMR, their reputation has gone to ****.
A lot of guys like the Melling. If you decide to go that route, this is the one to get:
http://s202.photobucket.com/albums/a...2132012906.jpg
#65
#66
#67
I use Melling oil pumps also in my builds.
I talked to some friends that are more educated about mod motors than me and they wanted to know if you pedalled the car (slick track)?
They said that if you pedal one with a stock oil pump, it damages the oil pump gears and cause loss of pressure. I knew that the gears in the stock pump couldn't take a lot of shock, but didn't know that pedalling a car was enough shock to hurt them.
#68
#69
Is it ok to even start one of these engines? Foe Christ sakes there is alot of don't's with them. How did they ever get this terminator/legendary status?.? With all these issues I can only think of 1 four letter word for them. It begins with a j
#70
my plan is as of now is to put a melling oil pump in it. have my engine builder to set everything at loose end of factory spec. and then it will be safe to run a little thicker oil and maybe an aditive. this is as long as the cranks not trashed. it will get a 7qt pan. and i will port and polish oil returns
#71
mine is f*****g j**K!!! how ever its never going back to pushrod again. **** that and **** a coyote. blows up 1 more time lsx!
#72
![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
No offense to you Heater
#73
#74
and i looked through the link heater posted on the pump. if you look through that photobucket there are pics of damaged oil pump. i think thats what it is. and definetly damaged bearings
#76
#78
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#79
Honestly, when I bought my Cobra I didn't know that much about the engines other than they were forged from the factory. After the first 3 months, I couldn't believe how many quirks they have. They are very finicky and have to be treated more differently than anything I have ever owned.
I would not change the tolerances when you have the engine builder put the engine back together. Just run what Ford recommends (Motorcraft 5W-20) and you will be ok.
