Street Racing & Kill Stories Basic Technical Questions & Advice
Death to HioSSiver!!
Old 04-30-2012, 11:10 PM
  #161
Tech Apprentice
Stopsign32v's Avatar
Old 04-30-2012, 11:11 PM
  #162
92cobranotch's Avatar
Originally Posted by Stopsign32v
108.9
i said a 12.0 bolt on mach. yours traped 108 at much slower et. corect?
Old 04-30-2012, 11:16 PM
  #163
Tech Apprentice
Who's to say someone couldn't drive my car or any other Mach 1 with a 108mph trap speed to a much better ET?
Old 04-30-2012, 11:19 PM
  #164
im not talkin about your car. what does a rainbow bolt on mach1 trap with a 12.0 et on average
Old 04-30-2012, 11:20 PM
  #165
Tech Apprentice
**** if I know or care. Ask someone that races numbers or someone else's car. I run my car and that's it.
I'm sure Autobot could tell us.
Old 04-30-2012, 11:24 PM
  #166
lmao autobot what do they trap?
autobot loves racing record cars did that ****** go to sleep?
Old 04-30-2012, 11:26 PM
  #167
Tech Apprentice
I don't know. He randomly shows up in threads concerning Mach 1s then leaves for a couple days.
Old 04-30-2012, 11:30 PM
  #168
he was always saying record 2v record mach this and that. i asked him what his ran and he didnt know lol....... although i dont know what mine has either other. i do know it has a rod knock and spins over 100mph on a **** track. and out runs hihos bike
Old 04-30-2012, 11:36 PM
  #169
mypoorLS1's Avatar
Notch you need to change your sig. . . "Was" faster than Hios fz6
Old 04-30-2012, 11:41 PM
  #170
snake95's Avatar
Damn dude, right out of the gate just bustin' his *****, although he is hanging onto the powdered rod comment for dear life (Kevin called that one )
Old 04-30-2012, 11:44 PM
  #171
Heater's Avatar
Damn, if I listened to Stoppy I'd be trading my Cobra in on a Mach and think that I was moving up in the world.
Old 04-30-2012, 11:49 PM
  #172
Tech Apprentice
I can't explain it...I've just never been fond of the 03/04 Cobra. I almost got a sonic blue one just like yours but backed out. List of things I dislikes:
1st gear ratio
6th gear ratio
seats
silver gauges
whine (I know I know. But I think it sounds like a firetruck)
HEAT
IRS
iron block
low compression
spoiler
nose, hood, skirts, bumpers
exhaust tone
power potential
As you can see it's just not for me. And I'm not meaning this as a bash! They just aren't my cup of tea. If I had one it would have the Eaton taken off, Mach 1 intake, and turbo. But then what's the point in owning a 03/04 Cobra?
Old 04-30-2012, 11:54 PM
  #173
snake95's Avatar
I'd love a Teksid 4.6 with tumble port heads (there are better ones out there but for the $$$$), 96-98 Cobra cams, some compression, and a Mach 1 intake.
Old 05-01-2012, 12:01 AM
  #174
Heater's Avatar
My Cobra is the first car that I have owned that I love everything about the factory styling. My only gripe is the dash is kind of dated.
To each his own.
Old 05-01-2012, 07:00 AM
  #175
lol be carefull ****** your luck is similar to mine.
Old 05-01-2012, 07:19 AM
  #176
mr. e's Avatar
It's rare that you hear about those motors eating bearings. Especially with the stock blower and stock crank pulley support cage.
I suspect contamination, or too low of an oil level.
Over the years I've pedaled my car MANY times without issue. I've done 5h gear pulls, sprayed on pump gas, launched of the 2 step, missed the 2 step trigger and rang the thing off the rev limit like it was my 2 step, missed 4th and went down to 2nd bouncing off the limit and wagging the tail, hot lapped it in FLORIDA heat, over heated it because an acorn got wedged in the fan... It wasn't until I hot lapped it with an AF of ~12.6:1 on 21psi of boost and a 75 shot that I finally killed the stock shortblock.
The photobucket pics several pages back were mine. The middle bearings received some bits of what I believe were from the oil pump gears galling the housing. The oil was a bit fuel diluted and the oil level was likely too low for what i was doing. Usually this causes a cam to lockup before any other sign that something is wrong.
Even running lean and detonating you're more likely to butt ring ends chipping the moly, expand a piston into the cylinder wall, torch a piston (all in that order) before you notice any hammering of the rod bearings or pinching off of a ringland.
Old 05-01-2012, 07:26 AM
  #177
assasinator's Avatar
for a racing motor i set the bearings at .002-.0025 and use nitro 70. just sayin. never a failure.
Old 05-01-2012, 07:51 AM
  #178
Best 60 ft was a1.9 so the car wasnt getting worked hard. should i have been running oil over dipstick full level mark? i did notice the pan is dented. ill have the motor out tonight. i want to see if the dent is bad enough its making contact with the pick up.. our ecu will pull alot of timing based on he coolant temp correct?
Old 05-01-2012, 07:52 AM
  #179
HioSSilver's Avatar
Originally Posted by snake95
Change your oil when the light tells you to? Wtf? I figured you'd take better care of your bone stock as is off the lot Camaro. BTW, another member summed it up best that your **** isn't stock...just like you've heard 8394290 times.
That's what the light is for. How would that be not taking care of it? I don't know how a stock longblock isn't stock. Explain that please.
Old 05-01-2012, 09:09 AM
  #180
snake95's Avatar
Explain it? You drive a 1999 Camaro. Did 99 Camaros come with LS6's?
...and to your question, depending on the light instead of watching the miles and doing it at certain intervals just sort of baffles me.
Quick Reply: Death to HioSSiver!!
