Mach 1 vs LS3 Camaro
#87
#89
#90
it's cool. my pinion seal is out again, which prob means the bearing is fucked as well. i just went through this **** like 3 years/20k miles ago. ******* 10 bolts. i just bought a gallon of gear oil so hopefully i can get the seal replaced before it runs out haha. i'd like to get an aftermarket gearset in it this time. i'm thinking 390s.
#93
#95
That's what I was worried about. I put some oil in before I left St. Louis and when I arrived in Indy it was at the same level as when I had left. I'm stumped at this point. No smoke and no leaks. I guess I'll just have to keep a close eye on it at this point.
#96
That sounds like a good idea. If you feel that you are losing more oil than you should, I would do a compression test/leak down test on it. Real easy to do on a 4V mod motor.
