384cid Z06,H/C C5, Turbo 2v, Nitrous Mach 1 , Cam Only Formula
I don't know how that stock stall/**** gear vette did damage like that. From a dig that first race against the 11 GT, ok, understand that one. The Mach race, (I'm at work, didn't have the volume up too loud), did the mach just **** up the shift bad and lose because of that? Looks like it got the jump, then fell back bad to a bad shift. And that stalled formula, I would have thought, would have done better against the vette. **** happens on the street though, thats for sure. Very nice video.
The guy in the formula is also my tuner! Car performs well with that small cam has a dead spot from a dig too about 25mph helps me roll out with zero wheel spin
Im intereseted too! But I wont go with out good air! My sigs alittle out of date but you can see were it says 2001 C5 h/c sold well same car just bought it back
#33
Yes Sir stock stall/ 2.73 gear works well on the street! Obviously theres still more potential with a aftermarket stall and 3.42 gear! Next mod on the list is a 3.42 gear!
#35
Next mod is a stall, forget the gears for now. Running a camshaft without an aftermarket converter is...no offense, stupid. Should have been your first mod. You are leaving a lot out of your setup. You think it works well on the street now...a stall would make it a dream.
#38
Considering Im the only auto c5 running around in this town other then the typical old men! I have nothing to worried about! Ive smack around a couple of bolt c5's stick shift tho! I mean If I did run upon one that left me sitting Id feel bad but until then Ill ride it out till I decide to get one!
#40
Sir if you think I'm ******* his setup you are even more uneducated. If you like your setup the way it is OP then more power to you. This forum is for people to give constructive criticism and advice to IMPROVE your setup. You are leaving a lot on the table. If you do ever get a stall converter, you will wonder why you didn't do it sooner. A lot of it will have to do with listening to people like SF4.6GT. Have no clue what they are talking about.
