Bolt on 02 z28 vs stroked 383 heads and cammed lt1 vs evo X vs 2013 5.0 videos
#43
its not bad its bottom end is built for spray.its just the forged 383 bottom end with a small cam .no heads,no suspension.wth a biger cam, good heads, suspension ,gears will be in the 10s on motor..pretty much its just a cam only motor
#45
sorry for how long it took to get the video up. Didnt go to the screen to see the numbers but like it said 416rwhp and 398rwtq. we would get another video or the termi now since the lt1 is tuned and lost close to 100 pounds but the termi got put in the shop for over heating problems and is getting a whipple now.
Also the tuner said that its a low compression engine. so everything is forged and low compression time for a d1sc
#47
416 hp with stock LT1 heads and a stroker built for boost? Do you have a picture of the dyno sheet? I'm not trying to be skeptical, it's just that I'm in the middle of an LT4 Stroker build, with fully worked heads and a comparable cam and that's about what I'm expecting to put down. I'm using speedtek's dyno as well and Scott Whitehorn as my tuner.
If that's true, then I'm probably going to overshoot my target by quite a margin.
#48
That 383 must have not been running right, it was sloooooow. A good friend of mine had a strong one and he would have eaten me alive when I was bolt-on/baby cam only. Would love to see some races once it's running strong!
#49
