800whp ZR1 vs 800whp Evo
1 Post
The ZR1 is a legitimate 800whp. Build thread:
http://forums.corvetteforum.com/c6-c...rformance.html
That Evo is just really fast car.
On a side note, why does the title say 800awhp but in the vid it states "830awhp"? How much power is the EVO actually making?
So just asking a question here and I'm sure I will get some intelligent answers and I'm sure I'll get those wonderful YouTube answers. Anyways so in this video the cars r suppose to be evenly matched HP wise yet every1 is crying that the EVO must make a ton more power the way he walked back on the ZR1 after he missed 4th. So my food for thought here is why can a less HP car run down and beat a more HP car? To me it could be gearing or how the power is put down. Just wondering why every thinks this video is BS?
On the other side of the coin, Evos aren't known to be good from higher rolls due to drag from bad aero (bad for top end pulls) and peaky powerbands from a big turbo on a 2.0L inline 4. Lets not forget short gearing.
Think about it. An 800RWHP ZR1 is NOT going to get walked by an 800AWHP EVO. Between turbo lag and aerodynamics a top mount zr1 would have pulled a bus on him if he had traction.
Evo is quick, just either has more power or the ZR1 doesn't have as much as claimed (which is what I think).
Because an 800rwhp ZR1 will be 150-160 trap car. That evo claims to be 150. Yet he walks the vette as if the vette is a stock c6.
I'm getting the trap speed thing don't get me wrong. I do believe the numbers aren't 100% correct. Now even if the numbers r from a 60roll I don't see a ton of boost lag being a factor or even break boosting will cause for such a massive leap ahead by the Evo. Still would like to see a rematch without the miss of 4th to get a accurate pull on the two.
Also that ZR1 wasn't breaking loose at all. All vids I have seen of high hp vettes they easily break loose at 60mph... just something to think about.
1 Post
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#33
Read the thread I posted from Corvetteforum. The ZR1 is indeed making 800whp, give or take for conditions. It has the modifications, has the backing from the shop, even the actual owner admitted the car was making the power.
I think heat can be another serious factor as a PD blower will generate more heat than a turbo. They only did one run so we can't know for certain. The ZR1 owner wants a rematch as well.
#34
#35
PD blower will be fine for a few runs. My maggie, which runs A LOT HOTTER than an eaton will take about 5-6 consistent pulls until heat soak becomes an issue.
If that ZR1 truly is what the thread claims then that evo must be pushing 4 digit power.
#36
I think you guys didn't see one of the mods the evo has, which is the upgraded final drive. The longer gearing helps it take advantage of that extra power it's making, especially with it revving to 8.5-9k rpms.
I don't know of any street evo's making 4 digit power and the ones that I've seen at those power levels are revving to 10k.
This is a 1000whp evo:
http://www.youtube.com/watch?feature...luRK3kdM8&NR=1
#37
Also, why are there two different dyno numbers advertised for the EVO?
#38
Dyno's could be a big difference too. Lets say the vette was on a happy dynojet in cool weather and the evo was on a heart breaker mustang in 100 degree weather. Factor in a little heat soak on the vette during that run and that could be enough of a difference to be that far apart. The devils in the details. Could even be a boost leak on the vette. Either way, badass cars are badass.
