MysticZ28 vs 2013 5.0
#61
1 Post
it really all depends... what are you doing with heads? I had a set of ported afr 205 heads paired with a 236/242 cam in it. That setup was strong only when i added a circle d 4000 converter. But the car was fast... especially for something that still had stock gear and an ls6 intake on it. But unless your going 4.10+ gear.... stay away from big cams. And dont give into that big cam hype. Yes my car had the best results with a bigger cam....but it was also a race car...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Fwiw, the fastest cam-only LS cars run big cams like the MS3/4, T-rex, Vindicator, Polluter etc. Big cams work great in a properly setup car.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#62
unless your stock tune has gone incredibly lean and is detonating bad, i dont see you getting 20whp from a tune. 5-10 is likely. A mid 230s cam is a good choice for cam only setups as long as you have the supporting mods to use it (4.10s).
#63
A properly setup big cam car turns them into **** when driving on the street... again, ive done it. I had the MS4 cam as a cam only setup. Ive had a Raptr cam, ive had a 224 cam, ive had an ls6 cam..etc etc. My gto had been turned into a race car because it was absolute trash to drive around on the street. It was an animal at WOT... but everything in between sucked. Was in no way practical. The setup in that car worked great...again...at WOT.
#65
1 Post
Looking at his post:
119mph? Good look with accomplishing that with a smaller sized cam. It can be done but it takes some real effort. However, something along the lines of a Vindicator, T-rex will do that with a 4.10 gear and a good efficient 4000+ converter. Keep in mind shelf cams like that were designed to take full advantage of the stock heads.
#68
That's complete Bullshit. Not all big cam cars run like **** on the street. I know of several local cam-only cars as well as many on this very site that run them on their "street" cars (not "race" cars as you say lol). Much of it is in the TUNE, as well as proper stall/gear. Saying a big cam can't be streetable is just as much of a myth as saying small cams don't make power.
The great and all knowing Redfire....
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
#69
i speak from experience since most of the cams i had were big cams... Id put my money into a killer cylinder head/intake and then later on spec out a cam for best power through the curve...
#70
We all of course have our own opinion of 'streetable', I daily drove (50 miles a day commute, rain, snow and shine) my old LT1 car with a CC306 and considered it to be street able... most of my friends thought I was nuts. Each person has a different level of tolerance for drivability.
Edit: Not implying that I had a big cam, just a notoriously shitty cam that most consider to much for DDing.
#71
why does it only count when the camaro wins? Jeez i watched the vid and thought it went down exactly as expected. Camaro got out on the launch and stayed ahead. Expected. 5.0 has better power to weight ratio and better gearing... it is the faster accelerator of the 2. On the roll, it had a slight pull... nothing ground breaking...but it did. Again, as expected. Idk why everyone feels the need to over analyze races. I thought it was a good race.
The Z28 did pretty good against the 5.0 in all three runs. I actually thought the 5.0 would've pulled harder in the two rolls but didn't.
#76
I went 117MPH in a small cam and a A4 at full weight with even the spare jack and tire in the car with out a big tb or fast. 119 is possible with an M6 and not that hard these days. You will need just about all the bolt ons including a ported fast,good air and about 3400 pound car with the right gearing.
As far as big cammed cars-its all in the tune especially with 102MM TB. Been in many MS4,T rex cars that drove well on the street. They need compression,gear, and a big converter to be nice along with a good street tune.
#77
1 Post
I love this thread by 'studderin'. Drove his big *** Streetsweeper cam-only car on a 1100+mi road trip, bump and go traffic and all. Says he "drives the car everywhere all the time". lol Old thread but still good.
https://ls1tech.com/forums/chevrolet...g-ny-pics.html
#78
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
#79
No the fbody can run 12.90 with those modes so the race went down about right with the 5.0 pulling on the big end. All you Ls guys should be happy the new 5.0 come out I was getting tired of picking on mules. See I come up when Ls cars first come out so if u had a mustang u thought u were the *****. I got more races then. So iam hoping the ford guys can have something to be happy about it was depressing wachting some of my ford friends they are still crying becouse Ls motors come out.
