Stock ZL1 vs Bolt on 5.0 (Video)
#41
#43
I guess google.com doesnt work for you. Here let me help you. https://www.google.com/search?hl=en&...hp.gYWNOpixctY
im not saying thats the reason it underperforms, because that isnt the reason it underperforms on single 1320' runs.
it has nothing to do with the 4120 LB curb weight.... Oh wait.
#44
As far as weight is concerned.... CTSV...nuff said. There heavier and perform better with less hp
#45
im unsure of the point you're trying to make... its like your trying to say something without actually saying anything. Care to elaborate on the point you're trying to make here?
#46
And apparently factory zl1s heat soak in the burn out box
ZL1 = poop.
And fyi, not sure why you took my comments to heart... they were never directed at you
#47
well no ****, i've said zl1's are factory garbage all along. But im not so sure CTS v's are that much stronger as they are basically the same platform. I'd have to do some more research to better understand the comparison.
edit: ok lol, I thought you were taking a dig at me for some odd reason, I was sitting here confused
#48
Now the ZL1... apparently heat soaks doing a burn out before a track pass. Thats just pathetic considering it was designed to be a road course car. Originally i wanted to see a test of the ZL1 on the road course going lap by lap by lap. I wanted to see a test on the blower aspect of it and if it slowed down over time. I guess its safe to say it would. One more reason to buy a 1LE over a ZL1. I think the 1LE would be my purchase if i bought a fifth gen.
#49
there's no reason a zl1 would heat soak and a ctsv wouldn't. they both perform basically the same, which makes sense since they're both so closely related. i also saw a video on streetfire where both cars are neck and neck.
people talk down on the zl1 but they're great cars. heavier than some full sized cars which is a lot for a camaro but it is what it is.
#50
Then the ZL1 doesnt heat soak. I can promise you from experience... the CTSV has 0 heatsoaking issues
#51
maybe it picks up heat from sitting still??
or maybe it doesn't heat soak and people just like to make excuses because they wish it was faster?? they're solid 117mph cars stock so they're not slow pigs by any means, people just like bashing them because they were expecting a 125mph car i guess (like the gt500)
#52
i heard gm specifically targeted heat soak when engineering these cars. it was all over camaro5.com when the engineers would go there and field questions on the cars. they said there would be very little to no variance lap to lap.
This is a big possibility
#53
+1,000
#55
I would guess that the 5.0 had nitrous the way it came off the line, I could be wrong though. I've smoked a CTS-V in the same fashion at the 1/8th mile track and I'm making way less power, it's all about the setup.
BTW, I have more fun or just as much fun at 1/8th mile tracks as 1/4 mile tracks and I'm really not sure why. Unless you have a high hp car, the back half of a 1/4 mile track is pretty boring. Maybe it's because by the time I'm at the 1/8th mile mark I shift into 4th and just ride it out, all the fun shifting happens in the 1/8th!
#57
#60
