Stock ZL1 vs Bolt on 5.0 (Video)
#64
the zl1 vert weighs a good 50lbs more than my full sized convertibe with a full frame/c6 auto/9in rear/big block and all steel body with only weight reduction being the wheels and exhaust.......of course the zl1 also does a lot of things my car cant do but they are pretty damned heavy for a camaro!
#65
The zl1 will heat soak, I see it on the dyno. They will climb 20-40* on iats after 1 4th gear pull about 7 seconds long. So does the ctsv though and when u pulley them, at least with upper and lower, they soak even worse if you don't put a decent heat exchanger on it.
My car with bolt ons felt as fast or quicker than a stock Zl1. That's a lot of driveline to turn and too much weight.
#66
And all these cars cut 1.5X 60ft's.
you can see the left tire come off ground.
#67
Even SVT thinks that car has more than bolt ons
http://www.svtperformance.com/forums...5-0-video.html
#68
I pulled the wheels about 2-3 inches with just bolt ons in my manual 5.0. Work-in-progress seen it. Huge 5-6k luanches do wonders. WBT pulls wheels also in his car and several others in their 5.0 with bolt ons. here soe that leave pretty hard.
#71
I am the owner of the 5.0, didn't red light you can see the win light come on in left lane announcer was saying the camaro is just watching the mustang red lights. Below is a video someone else took earlier in the night against a Z06.
#72
car has a bolt on roush 2.3L supercharger through closed air box. Motor, trans, converter and suspension are all stock. Full weight car with NAV and i weigh 300lbs. Supercharger vs supercharger,
#73
http://www.youtube.com/watch?v=EV9lA...=youtube_gdata
#77
#78
King of turds = Mopar
#79
