Cobalt SS Vs CTSV - Video
#45
#46
Sorry if things don't add up for you.
#47
My cobalt had cai, full 3" exhaust, poly motor mounts, upper charge piping and a 93 octane tune going from 29psi spike to 27psi and I was pushing 311 whp 383wtq. With e85 (DI turbos LOVE) I could see him pushing 350whp+ to 400wtq+. I've seen those numbers before. Plus being 3000lbs is a big help
#51
I'm not saying the cobalt shouldn't win, but that was down right embarrassing. To top it off, then the NA fox body stayed with him and at times pulled. I'm just trying to put 2&2 together. I guess anything can happen on the streets.
#53
Willzm, the above point is what I'm trying to make. I ran a full bolt on cobalt at 3000ft altitude and it was ugly for him when I was stock. Now he wasn't running E85 at the time but still.
Keep in mind I trapped 109 with dp and pump tune
#55
What tune was the cobalt on? Reason I ask is there a big enough difference between a gms1, trifecta, and custom hptuners tune.
#56
E85,...if anyone has not tried it...it is incredible.
My truck,...flex fuel,...has a "economical tune" in it from my Trinity(diablosport)(custom). It isn't tuned for E85...but, when I do run E,...the vehicle wakes up like you would not believe when I run it on E85 with no other changes. It feels like I picked up about 30 horsepower(very heavy vehicle).
Now my vetter,..on the old setup...making roughly 800rwhp on 93,...would have made around 900rwhp or above on E85....being tuned for it. If not more. The fuel is indeed amazing,...it smells kind of exotic....it does use much more fuel though. My Tahoe gets about 3mpg on avg less.
You can convert a vehicle to run both fuels,..just need to get a flex fuel sensor,..and wire it to your pcm. Run both,..or whatever. I have not set up a flex fuel sensor on my vette but....maybe one day I will. Fortunately, E85 stations are all over the place down here within reason.
Yes, I realize most of you know ^^^ but...for those of you that don't...... it's the Bee's Knee's. A real HOOT.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#57
Let's do some ricer math quick...
CTS-V - 556hp / 4250lbs
Usually dyno ~480rwhp stock
Subtract about 20% loss due to altitude, 6000ft and you end up with about 384rwhp UNCORRECTED.
So 384rwhp and 4250lbs is about a 11.1:1 power to weight ratio.
H/C/I LS1 Camaro - 426rwhp / ~3400lbs
Subtract only a ~15% loss due to increased volumetric efficiency helping negate effects of altitude and you get 362RWHP UNCORRECTED.
So you get 362RWHP and 3400lbs = 9.4:1 power to weight ratio.
Cobalt SS/TC on E85 with bolt-ons - Probably about 320whp UNCORRECTED and 3000lbs. (Don't know my dyno number, but most cars with a similar tune and mods make 340whp-360whp and around 400ft/lbs)
320WHP and 3000lbs = 9.38:1 power to weight ratio.
Races make sense, especially when you consider the CTS-V is a bone stock auto and I'm sure the torque abuse programming in the lower gears really hurts it because if you watch closely, the CTS-V doesn't fall back as hard once we are over 70 or 80 mph.
#58
You pulled that V as if he was trapping 99mph at most. NOT saying your car ain't running strong. My V is/was cammed, pullied, full exhaust, ported blower with supporting mods.
#60
i would have kept mine forever if it was RWD. i cant really fit into a sky or solstice.
fastest FWD factory car to go around the ring... cant deny that. and they make crazy power with relatively inexpensive mods
