Street Racing & Kill Stories Basic Technical Questions & Advice
340whp WRX vs 416 gto - street/dig
Old 10-27-2013, 04:52 PM
marc97taws6's Avatar
Props for running the car and actually posting up numbers! Half of the guys who talk the most **** on this section won't do the same.
You may not be 100% happy with them, but it is a new setup and I'm sure you'll get all of the bugs sorted out soon. You have all winter to anyway
Old 10-27-2013, 05:09 PM
Cwarta's Avatar
Thanks everyone, the car is 60' very well, how would you say a 7.50 1/8 mile @94 sound with a 1.77 60'.
Ive said from day one, these heads are going to hold me back. Ill get some vids uploaded, but its leaving hard and then falling on its face up top. COupled with 4th gear rejections constantly its getting irritating. Everyone is posting a million videos to facebook but that does me no good here lol.
I raced Blakern here on tech, it a turbo/stalled auto T/a. He was running 11.2`s@127. We raced and went door to door 1/8 mile then started pulling away hard top of third. Im happy with the 1/8th mile but its dead the rest, but still picked up 27mph on the big end. wtf?
Old 10-27-2013, 05:21 PM
evangto87's Avatar
Have you had the car on the dyno to see what the curve is looking like? If youre having a problem... its going to show on the dyno. What are the specs to the motor... part for part?
Cam, heads, intake, weight?
Old 10-27-2013, 05:23 PM
sw07gt's Avatar
Spray through it. Problem solved.
Old 10-27-2013, 05:32 PM
evangto87's Avatar
yea i wouldnt do that. Just read your sig Cwarta. I think the problem is your entire top end. Vic JR is a ton of problems on an NA car unless you have a way of measuring flow. Has it been worked at all? If you are spinning that motor under 7k... throw that thing in the trash. Your heads are definately a bottle neck as well but you can still go faster with them. My money is on the intake/cam combo.
Old 10-27-2013, 05:51 PM
Lawhead's Avatar
Heads and a Gear swap and that car will be a monster that cam is going to want near 7500-7800 if he gets the heads to support it
Old 10-27-2013, 06:07 PM
Cwarta's Avatar
Next step is that, to get it on the dyno. I need to see whats going on, I got a few vids that my friends are supposed to be uploading to facebook. I wentdoor to door with 4,000 stalled auto/turbo/slick T/A that ran a 11.2@127. We launched together and stayed door to door in the 1/8 and then the car just fell over... I have a vid of that, aswell as an incar vid of my shifting/launch im trying to get uploaded.
Its an Lq9 bored .065 block, callies dragonslayer 4" stroke crank, eagle 4340 H beams, manley platinum series pistons, cam is a 243/255 .634/.624 on a 110+3. I had Ed Curtis spec the cam for these exact heads and this intake/TB setup. I have a hard time believing its cam and intake problem. The car is making power down low and leaving hard, but its not carrying it out. Exactly the opposite we should see with it if its an intake problem since its a short runer intake.
Im shifting around 7,200. ANy higher and my trans wont shift. I need a tick adj master desperately. But it doesn't "feel" like its laying down really, its just not backhalfing. AS of right now the intake and cam are the last thing ill throw the blame at. I think I "May" be floating valves or something, I have cnsc ported ls3 heads that will be going on.
I have cnc ported ls3 heads to go on, and I have 3:91 rear gears.
The blue gto went 12.01@116, and I pull away hard for the 1/8 and then not so much. Hes sending me over the incar vid.
Old 10-27-2013, 06:09 PM
evangto87's Avatar
Thats a heavy car... a reving setup IMO isnt right for it. My buddies 403ci ss is just under 3700lb race weight and he has old *** stock AFR 225 heads(dont flow **** in comparison to late model heads), a vengeance fast 102/102 and a 248/254 cam. It makes power till about 6800 and made 560whp. Just went 10.6 at 130.7 this weekend. I still say... of the 3 major parts of the top end... the intake and cam are the problem. Mainly the intake
Old 10-27-2013, 06:10 PM
Cwarta's Avatar
In car vid of me dead hooking so hard it lifts my foot off the gas pedal.
The cummins in this vid ran bottom 12.s
Cwarta's Avatar
Lawhead's Avatar
3.91's aren't enough that car is going to want 4.30's 4.56's if you're looking for the best track numbers you can get which it seems to be more of a track car with the way you set the car up IMO but I can be wrong
Old 10-27-2013, 06:11 PM
  #32
evangto87's Avatar
Oh and watching and listening to your videos of racing on the street. It doesnt sound like its nosing over at high rpm... it sounds like its ******* pretty hard coming back into the next gear. And reading your time slip... Its not really MPHing in the 8th that well either. If you ask me... The gains from the 8th to the 1/4, mph wise, are a lot better then your 8th mph
If you plan on reving the car 7500+. You want 4.56s+
If you plan on keeping the revs below 7k... leave the 3.90s.
You have to commit to a setup. Have to set the CAR up.... not just the motor
Old 10-27-2013, 06:14 PM
  #33
Cwarta's Avatar
I know, the car does feel like its nosing over, but its not performing on the back half.
3:91
Incar vid of the dead hook
Old 10-27-2013, 06:15 PM
  #34
evangto87's Avatar
93mph in the 8th... you car is actually picking up strong in the back half. Its the 8th mile that is suffering.
Edit... just watched that last video. Sounds like the motor is working right for its setup... but it doesnt match the car.
Old 10-27-2013, 06:23 PM
  #35
Lawhead's Avatar
That Diesel truck was getting down!!
We watched one go low 9's at Nam last weekend
Old 10-27-2013, 06:25 PM
  #36
Cwarta's Avatar
Idk what to think, it seams to run good but not mph like it should. I don't see how it needs more gear when its leaving hard, not bogging the **** out of it and not really bogging on the shifts. I think it needs heads, yes. But I don't believe this is the only problem.
This Turbo trans am went 11.2@127 on this run. We had almost identicle 60' R/T etc but 1/8 was close and then he just takes off afte rthe 1/8
Old 10-27-2013, 06:28 PM
  #37
evangto87's Avatar
Post the time slip of you and the TA
Old 10-27-2013, 06:29 PM
  #38
Cwarta's Avatar
Here is axactly what im talking about. Incar vid from the Blue gto. 12.01@116 for him.
I pull so hard early and then fade off....
Old 10-27-2013, 06:32 PM
  #39
Cwarta's Avatar
Ill see if I can, I lost every single timeslip I have, including the one I posted already. Made the mistake of rolling down the window while driving....
Ill see if I can get it from him.
  #40
Lawhead's Avatar
Looks as he was actually catching you on the big end.......Exactly where you're choking that Cam and intake LoL get them heads on that thing and you'll be a happy camper man
Quick Reply: 340whp WRX vs 416 gto - street/dig
