Bolt on 5.0 vs Cam only C5Z
#141
See you have it mixed up, this is truth.
Truth- the quality or state of being true.
The definiton of myth is below. I know MISSISSIPPI suffers with ed-u-ma-cation, but here you go:
Myth- a widely held but false belief or idea.
#142
yea 5.4's are junk.
????? are you retarded?
I don't care if it comes out of the Ford Racing or GM Performance Parts catalog, you know good and well I was talking about something other than stock. I don't care if it's a "replacement," or uses a factory casting, or if a tune isn't necessary. If it didn't come on your car, it didn't come on your car.
#143
#145
Yes the myth that none of the older n/a modulars could hang.
#146
#148
#149
Heater, I like you man, but that is an audacious statement. Overhyped? Well, the LS started in production cars in '97 with a top NA output of 350/345. This reached a height of 405/400 in the end of the gen III engine production by '04. In this WHOLE time ford didn't have A motor to compete with it. In '06 the LS7 came along w/ 505 NA horsepower. Ford FiNALLY created a much heavier competitor in the S/C 5.4 for the Ford GT. The 5.0 is a nice NA motor, but give GM credit here. It took Ford 13 YEARS to have an NA motor to be competitive with the GM NA offerings. Not to mention, 2013 was the first time that Fords top engine offering out powered GM's top engine offering. Even the sun shines on a dogs *** every once in awhile.
I'd say the hype wasn't hype at all. More like production.
I am flattered that you like me
Let me switch this up for you, so that maybe you see where I'm coming from. Do you think 03-04 Cobra's are over hyped?
I put them in the same category as the LS, over hyped.
Doug, in your mind you see nothing wrong with saying that my engine has no Ford parts in it. Reality is you are being condescending and trying to use the OEM angle as a way to discredit my engine.
Just so you don't jade everybody's thinking that are not as up on other cars or engines, I have built or hand my hands in several engines. Including this was a high school buddy of mine that built a budget SBF mainly using FACTORY Ford parts.
1971 model Ford 351 Windsor block
Stock football rods
Stock cast crank
Stock 4V Cleveland heads
Stock replacement TRW piston that we cut for the Cleveland valve reliefs
Hydraulic flat tappet 292 Competition can
This stock engine with a cam ended up running 11.50's in his 1981 Ford pick up truck. It was damn impressive for 1993 for a truck with a engine with so many OEM parts running that fast...oh yeah and it was his daily driver.
We put port plates in the heads to slow down the flow (they flowed too much from the factory) and it ended up running 11.20's on a borrowed set of big and little Pro Stars.
#152
#153
Not at all. The proof is I can go buy a k member to fit a ls into Mustang........but not the other way around.......hhhmmmmm Does that tell you anything.
You see no one goin to the junkyard and getting a 4.6 or 5.4 out of a truck and trowing some turbo's on it. Why is that??? Maybe because the will spill their guts at anything over 450whp.
Furd made a good rear in a 9'. But they did'nt make mine. It's all aftermarket like heaters engine.
Stock football rods
Stock cast crank
Stock football rods
Stock cast crank
Your buddy had a good combo. That's the type of **** I like to see.
They are not really that heavy. Heavier than a 4th gen, but a 4th gen would be about the same with the added weight of a blower.
#155
Not to mention his aftermarket **** he has anyway. I don't think he remembers that he has non GM **** on his car. Maybe when his drilled hood hinge snaps and pushes his face to his FAST he will see what we are trying to say.
#156
#157
Guys on hear like to yak about my holes, the only ones you can see are the hinges and in the fiberglass support btw. In reality there is only about 20lb gone in holes......maybe less. And none are in the chassis.
Not that I'm worried. That pos carbo hood will break long before the hinges.
#159
241's are fine. If notch would've finished his car you might've had a hard time getting away fro a set of 241's. Last time you posted head flow #'s you did it at a lift you can't get to with the furd head.
You're a dumbass. I still have my door bars. Where do you come up with this ****?
Your not gonna go out and run a 11.8 n/a. You'll be lucky to get to a 12.8.
As I said.......*** hurt when a camaro get's near the weight of a fox. If you were smart you would do what the rest of the world is doin and put a LS in that tin can of a chassis.
Last I checked the fp'd t56 don't stop me from goin anywhere.......not even in the snow. But a set of slicks would.
Ask heater about his fp'd trans in his fox. You know the street car with no wipers.......and a Chevy hood.....lmao
I didn't cry about Heater's power. I simply made a truthful comment that he was looking for out of me.
60's????? WTF are you talking about? It took furd till 2011 to out run a ls1.
I didn't discredit it. I said what it is. There's not much ford left there. If you think the sbf is so great then you should use ford parts. I'm putting my money where my mouth is and using gm parts.
What's the plates for in the bottom of your floor?
Not very ******* good.
Not really........you would struggle with a solid full bolt on ls1.......in 2014. Last I checked it took more than a head to get down a race track.
You don't have an LS in your fox, how do you contradict yourself so much ?
#160
are we really arguing about mod motors vs ls motors....AGAIN?!? god this stuff gets old quick. The fact is any NA mod motor (pre new 5.0) will not hang with the LS bolt on for bolt on. When the FI topic gets brought up, its only a fact of who has the deeper pockets which is irrelevant because very few of us discussing this topic has the cash to dump into a car.
