Camaro Z28 vs H/C 306ci Mustang
#81
It's posts like this which shows the amount of nut-huggerness. What would you have said if that SN-95 actually had a good heads/cam set-up that would've dragged that cammed Z28 down the road? Excuses along the lines of "there's something seriously wrong with the Z28 and/or driver couldn't have drove any worse" comments would've came out of the woodworks.
#82
Good point MAC and yes that's true some of the Mustang crowd does the same, and I say the same to them. Sometimes it really seems like a lot of LSx folks on here have absolutely no idea what a nice 302 heads/cam car can do. Back when I had my '89 notch a few guys in my crowd had heads & cam 302 or 306 Foxbodys which ran high 11s very low 12s n/a. And they all were nitrous cars on top of it. Not the usual crap you see here on SRK.
#83
Like I said that would take a great day and probably a icing down with a tire on it.
4.10's are not great from a roll. Besides you completely over looked what and how it was said. The m5 gearing is much better from a stop regardless of gear.
#85
Just be glad I don't have extra time and money or I would find a notch and put a Chevy in it like everyone else. except I would use a 305 with gm heads and drag your ***.
#86
I dont think any engine is bad i believe you just need to know what your doing and have the right combo set up properly. Hell you can always bore out and stroke the 305 and put some sort of F.I. on it an im sure it would make good numbers for what it is.
#88
***Repost Police***
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#89
Dur durrrr durr.
305 would be a good motor if you "bore and stroke it out". Derp herp derp.
Mac, breaking news!!!! Boring and stroking a motor increases the cubic inches!!! Would no longer be a 305!!! Mind=a-bomb'd.
Mac can count to potato.
#91
Snake my point is that if you know what your doing any motor or engine can be built to put down respectable numbers for what it is. Do i need to explain it any more clearly for you or did your caveman brain grasp that?
#93
lol i think it did great given the mods on the f-body. Most H/C/I 306 Notch's are unimpressive, From first hand experience. This is an SN95 we're talking about here.
#94
I started talking Foxbodys because the SN-95 is the same platform and they run nearly identical with identical setups.
#97
Exactly so how is the 305 terrible like snake said? Idk why he must piggy back all my comments. I guess it makes him feel better and all gooey inside..... again like i said any motor or engine can be built good and put respectable numbers for what it is. Guess thats too hard to understand for some people.....
#98
#100
Just to add fuel to the fire about ford engines and chevy engines power block tv did a show on the old big blocks back in the day and the Chevy 454 destroyed fords big block
no contest what so ever!
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
