2004 Mach 1 vs 2004 GTO
#43
Honestly, there was a ton of bad info floating around about 331/347s for the longest time and that's why a lot weren't all that much faster than a heads/cam 302. People putting 185 heads on a 347 because ermagherd 205s+ would "kill low end torque" and "hurt velocity"...or GT40/GT40p/GT40x heads and they'd run even more sluggish. That mindset is still alive sometimes on Corral and it kills me...
#44
#45
...and if you ask me, there's nothing wrong with swapping over to a stroker with the same parts as long as you're okay with the fact that it's not going to "increase" power by much, but it'll move it lower in the rev-range.
I probably sound like a broken record but Kevin (Stopsign) made 456rwhp N/A with his 331 stroker. Trick Flow 205s & off the shelf Comp cam. Nowadays, the info is out there if you go to hardcore50, sbftech, yellowbullet, etc. Corral is sloooooooooooooowly getting better but I mean slowly. Still lots of 65mm throttle body and B-cam recommendations floating around there, too
#46
Yes! In one of the other LS1 circle jerks I tried to explain this. I was 19-20 when i did this 347 build. My HCI 5.0 put down 310rwhp, I built the 347 stroker but didnt have the money to upgrade the H/C/I so i just transferred those parts over onto the 347 with the plan to upgrade them at a later date. Ended up selling the car to buy a house before i did that. I put down 359rwhp with that set up. Ran 12.2 on street tires because i always run my cars in street trim no slicks skinnies for me. There is no talking sense into LS1 drivers. Wierd part is when i had that car i ran several buddies with LS1s and smacked them. Somehow on this site they all run low 12s pretty much stock.
Yea did the same thing hear with my build except I retained completely stock heads, and still put down over 500rwhp and 490rwtq thrue gears and irs.
Not bad for a turd LS motor. My Cammed lt car had been mid 12's up here in 3,000 plus D/A also and it made a single pass, like a 1.9 60'
#47
#48
Yes..you are correct. When i was researching cams for my car, I looked at the lift and durations for the stock cams and noticed that they are pretty close to the FR500s. The FR500's were a little more aggressive though.
#49
Only mistake I did with my 331 was reuse my extrude honed intake. I wanted something from my 302 to reuse. I finally replaced it this year with a Tmoss Ported Holley. Wish I did afr 205s and more cubes with that r block.
Snake is right about the Corral. P head this,Fms cams that....blah blah blah
