79 camaro 454 h/c 700r4 vs exhaust only 99 camaro
People will overglorify anything and everything. Not all BBCs run great. They are setup dependant just like everything else in the world. It's a very mild build, thus, very mild performance. Nobody should be shocked here...
That combo on that 454 in the Camaro sounds so far off its not even funny..
First there is no "pink" rods for a BBC...that's a small block rod... Next, square port heads are TERRIBLE performers at best.... Unless its a solid flat tappet or roller that you can spin to 7k to make power... those heads don't even START to flow until 5000+...Which more then likely his mild cam is already done by...
That comment about 454s with square port heads and solid flat tappets making 600hp all day/every day is hilarious.....
And I guarantee you that 79 Camaro is heavier then 3400 lbs..... Probably 3600lbs before the driver weight.
Takes a lot of work to make an old tech motor (SBC or BBC) run with any well thought out LS..... (this coming from a BBC guy)
