calling out snake95\ other 5.0's!
#1342
I actually did throw some data out of why the 305 is inferior. Things that really matter to engine output like bore size, and compression ratio.
What don't you understand about this challenge? Stock weight street cars, stock bottom end motor. Pretty simple stuff. Snake is being nice and letting Hammer correct the shitty compression.. He doesn't have to. The guidelines were clearly stated.
#1343
Hio, stick to the **** you know - not Fords. I know the messages are flying back and forth between you and hammer, go ahead - he's gonna need it. We agreed to video before hand to prove it's streetable and not a race car engine. ****, even if he ran 12:1 with a donkey dick cam and built bottom end, it'd be close with my basic heads/cam car.
I fully expect to find about 5 loopholes exploited at the end of this whole thing, if I didn't ask about pistons & compression, it would have gone unmentioned.
#1344
I never said the 305 was junk. I wouldn't waste my time on it though... To many 350's out there.
#1345
A SBC head flowed on a 4.125 bore will outflow the same head flowed on a 4.030 bore. It does matter. Quite a bit actually...
#1347
Now that you guys have figured out that your cars don't weigh 6 tons and are adding chinese made Arias intakes good for 60 hp (Hammer), I should get something back. How about getting rid of the DQ even if I win part of the rules?
BTW: I just broke an axle speed shifting to 2nd so it probably won't even make a full pass
#1350
They are both using after market heads. Snakes 4.0 bore is much better than a 3.74 for head selection and valve sizing. You can't just throw any SBC head on the 305.. It is certainly not anything close to stock vs stock.
#1351
if i were just building an SBC i wouldn't even bother with a 350. it would be 400 based.
#1354
Please dont take that serious obviously im joking around...
#1357
In that case I'd go big block... really no reason to use a GM 400 block. Dart blocks are cheap and much stronger than any GM casting.
#1359
MAC, honestly man nothing up my sleeve. Just a H/C 302 with off the shelf parts. I don't have the $$$ to do one-off **** or expensive parts.
#1360
Cool.. I see you worded that intending on changing pistons because GMs design is inferior.
That sounds like a great idea... limit yourself to .4" lift, or sink the edge of the valve into the bore So in your opinion, neither of these will limit head flow? I said you can't put any SBC head on a 305. I should have said you shouldn't. My bad you didn't understand that statement.
it wasn't clever wording. obviously if you're boring, it's raising compression even if you stick with stock style pistons.
it's not .400, it's around .450. and you can run a 2" valve down into the bore without notching.
you've obviously never built a 215cc headed 406.
