Street Racing & Kill Stories Basic Technical Questions & Advice
Mustang II strikes back...
Old Aug 23, 2015 | 09:56 PM
  #61
HeadsOnly's Avatar
Originally Posted by V8EATR
Was there something competitive in the video I posted? Didn't look like it to me. What does that say for the 5th gen?
5th gen was much faster than any Mustang GT when it made its debut in 2010. And it's only taken GM a few years to gain back the lead with the 6th gen. Not decades like it did Ford. If you'd even call that a lead. 5th gen is pretty even with 5.0s.
Old Aug 23, 2015 | 09:59 PM
  #62
Lawhead's Avatar
Sure hope the 5 1/2 gen does better than the fif gen
Talk about a flop
Old Aug 23, 2015 | 10:01 PM
  #63
HeadsOnly's Avatar
New LT1 camaros are going to train **** 5.0s, big time.
Old Aug 23, 2015 | 10:02 PM
  #64
Lawhead's Avatar
Sure hope so Mystic !
Old Aug 24, 2015 | 01:55 AM
  #65
Gt4urass's Avatar
I like 3 valves.
Old Aug 24, 2015 | 06:50 AM
  #66
Mappinsj's Avatar
I want a sixth gen camaro so I can sit in it all day.
Those new seats look comfy
Old Aug 24, 2015 | 08:09 AM
  #67
NW-99SS's Avatar
They aren't needed. Mod motor cars have been in the 6's with stock blocks and heads.
Wrong mr new automach.
The blocks run by Mihovtiz (sp?) are fully modified Ford racing blocks - not stock like you suggest, same with the heads.
Either way 6 seconds cars have absolutely zero bearing in this thread.
Old Aug 24, 2015 | 08:17 AM
  #68
HioSSilver's Avatar
^^^^^Lots of troof in that post
Old Aug 24, 2015 | 08:31 AM
  #69
islander033's Avatar
7 Second Club
I fully agree that *5s cars have nothing to do with this thread.
But...
http://www.accufabracing.com/john-mi...vetz-mustang-2
from linky:
What made John's power and speed so impressive is the small displacement and stock source for major portions of his engine program. Displacement is 282 ci-- call it a stock 4.6 liters-- using a stock aluminum Cobra block; stock old style, "B" dual-port, Four Valve cylinder heads, as found in a '95 Lincoln; and a stock 4.6 liter Cobra crankshaft.
Carry on!
Old Aug 24, 2015 | 08:43 AM
  #70
HioSSilver's Avatar
Originally Posted by islander033
Where are all these fast bolt on LS1 cars that you've had anything to do with?
I know where Hammer's is.
I helped and drove nathans to 11's.......right there is one. Easy to duplicate to.
Actually you should consider yourself lucky behind your keyboard there that nobody with a coyote powered vehicle that has been hole sawed down to your weight finds you.
Be a good run for furd to keep up with 2002.
Old Aug 24, 2015 | 08:51 AM
  #71
7 Second Club
So....high 11s is fast for a modded car? wow
Old Aug 24, 2015 | 08:54 AM
  #72
HioSSilver's Avatar
Originally Posted by marc97taws6
Still stuck in the 90's I see.
I'm sure there are plenty of Ford guys who could have swapped their motors to go faster like Doug did as well.
Wtf you gonna swap? You wanna whine about my weight then swap a coyote into a 2600lb notch to compare?
What all do you need for this "swap"? You don't even ******* know. You know what i needed?.......nothing but tge motor. Apparently it's the holy grail of swaps when a engine bolts in like it belongs there with nothing special.....no mounts to change, no wiring to change......**** it even went faster than almost all the coyotes that's ever posted on ls1tech on the ls1 tune
Originally Posted by bth2278
Well than you can't hate one hio's setup. Nobody hates on a stripped down foxbody lol you couldn't take a 2v/3v mustang gt and do bolt on and weight reduction and run what hio runs
Lol....troof
I don't hate on his setup at all. Him acting as if his setup is the norm is what I dislike. 15+ years of re-engineering a car is not exactly an easy process.
It is very much the norm if you know wtf you're doin. I can see why you don't think it is.
It hurts it really does. When your sitting at a red light and there is a 5.bro next to you but he hears the cam lope and immediately throws his blinker on. Brings me to tears every time
Lolz
Old Aug 24, 2015 | 08:56 AM
  #73
HioSSilver's Avatar
Faster than these modded coyotes
Faster than a whole pile of pullied gt100s to
Old Aug 24, 2015 | 09:14 AM
  #74
ZNix's Avatar
Originally Posted by Nick.H
Mystic
Yep.
Old Aug 24, 2015 | 09:17 AM
  #75
V8EATR's Avatar
Try using the internet, there is thing called google and you can search stuff. It will bring up lots and lots of lightly modded coyote mustangs in the 11's. And yes a motor swap in a fox isn't really any different than what you did. You know damn well the only reason your car is fast is because you hole sawed 50% of the weight out of it, nothing else.
Old Aug 24, 2015 | 09:21 AM
  #76
ZNix's Avatar
From what I've seen in the Coyote Stock class, the Coyote motor in a Fox would whip on you Hio. They are running 10.50s at 125mph.
Old Aug 24, 2015 | 11:11 AM
  #77
V8EATR's Avatar
True and they have a huge weight penalty as well now, in 11 and 12 I think when they were the same weight as everyone else they were running 9's, now I think they are even heavier than Hio's car and still running faster.
Old Aug 24, 2015 | 11:21 AM
  #78
7 Second Club
Wrong and only the ones that need maintenance.
Old Aug 24, 2015 | 11:35 AM
  #79
big hammer's Avatar
Pretty desperate when you're comparing a normal street car to motor swapped class racing cars
Old Aug 24, 2015 | 12:18 PM
  #80
HioSSilver's Avatar
Very true hammer.
Yea i don't think a coyote swapped fox race car is comparable at all to my car. Besides those cars are leaving at full tilt on slicks with a real racing transmission.....and lighter. Coyote stock has a 3000lb weight.....so more bs spread about by v8queerer who has yet to make a pass in his own car. Link to weight http://www.coyotestock.com/
Furd guys keep reachin for others when their modded coyotes don't run 11's like they say.
