Poppacap vs mappins!
#561
I don't downplay anything. You simply don't like the truth.
What are we downplaying?
Poppa got emailed a tune, he hooked a handheld tuner up to his computer and loaded the tune onto the handheld, he plugged the handheld tuner into his car and loaded the tune, he went to the gas station, inserted his card of choice, selected the fuel of choice, lifted the handle, and gassed up his car. After he was done gassing up, he returned the nozzle and went on his merry way and took his receipt.
Pretty simple if you ask me.
Poppa has flex fuel.....a sensor woukd be needed for that also. You also downplay how much e85 helps.
Troof
Well if notch's car picked up 25 on the back half like it did. And hammer's car is faster than his then we would be looking at 120+ for hammer easily.
Yes.. they do downplay their mods... quite a bit. alot of work went into their mods and weight reduction. maybe I will start a Post Your current scale weight thread... Im sure they wont post in it.
If they ran the same raceweight I do, it would be like my car running a Prius
Keep downplaying e85. That's the only downplay goin on here.
Can we run the same trans too? I'm sure the coyite would be great with a a4 and normal type gearing behind it.
#562
Notch's car had about the same wr as you.
You're downplaying e85.
Nothing shady here. Hell you guys used to resight my mids lime it was your bible.
Troof
Aggressively geared auto....sure why not? There us only 17yrs of difference.
But none need a scarce fuel like the 5br0
I've posted my weight plenty. You guys cry about it.
Troof
Wanna know some truth? Poppa can put E85 in his car and all he needed was a tune to do it, that's the truth you big *****.
#563
Dunno, I haven't been to the track since I was bone stock and I ran a 12.1 @117 stock. I'd say I'm somewhere in the 11s now.
#564
Real world results that I've seen first hand with friends and acquaintances, e85 picks up 7-12rwhp over 91 octane here on a dedicated e85 tune and picks up maybe a tenth at most, being the only change on the car.
These are first hand, eye witness, real world results. Not crap I've seen on an internet forum.
I didn't really notice much of a difference, as I expected with the butt dyno. Another real world, first-hand result.
Poppa will pick up less since his tune isn't a dedicated e85 tune. Poppa would also pick up more power than the maybe 7-10rwhp tops he got from the flex fuel e85 tune deleting cats from his car or replacing the resonators with straight pipes.
#567
But yes, a Coyote motor and 6r80 transmission in a light platform like a base ~3200lb C6 would perform well.
#571
I was going to use it on the 98 TA build with the Holley HP ecu setup.
Love my car now though so glad things ended up as they did.
#572
As cheap as you can get a LS1 pcm just buy a used one and get a E85 setup in one. You probably already know how easy it is to get to a PCM in those cars.
#573
How can you even say something like that without feeling like a total ******* dumbass. You're the biggest hypocrite on this entire forum, probably on the entire Internet.
Poppa has flex fuel.......ever heard of a flex fuel sensor dumbass?
None near me. Lots of threads on here about peoplw that doesn't have it near them either.
#578
As far as the second quoted paragraph - that's not my problem.
#579
