Cam/6.0L T/A vs Bolt On 99 Cobra
#241
But back to the thread, do valve springs change the head or is it considered hardware? Honest question, no argument. Because you can buy a head with nothing on it or dressed.
#242
All the fast ones look stock because they are just a great looking car. No need to change anything. One of my first humbling experiences was when I got beat by GN, I had a big block Pontiac that was pretty quick, just not quick enough lol.
#243
Only thing you said is that you know the difference because your notch is termi swapped. Truth is that you didn't know what the 1st gear ratio was. I corrected you and you disappeared from the thread. You are only proving that you aren't man enough to admit when you are wrong.
Hammer needs to get to a 1/4 mile track to put all of the bench racing to rest.
#253
#254
The 03/04 heads are good for about 10-15whp. The 04 heads also have the 9? thread spark plug holes instead of the 5? thread and don't have the coolant flow issue the older heads did.
FWIW, I would call what modular man did no different than a ls1 car putting on 243 heads and an LS6 cam. Still factory stuff that bolts up. No big deal and not worth a ton of power on either side.
#255
The cobra is not bolt on. And all he said was that he would make "ls fanboys look silly".
#256
#258
#259
