Stock Boss 302 vs LBO 6gen
#783
[QUOTE=HioSSilver;19398267]Nope....you're a lier
So put bith cars back to stock and run them?
[/QUOTE
That's your words, telling Poppa to take this and that off. What about Phil?
[/QUOTE
#784
Troof
Depends i suppose. Poppacry had raised limiter to. Poppacry also has other mods that help acceleration. Should those be removed?
I could see you being that big of a pain in someines *** instead of learning to do it yourself.
You guys want mod4mod......so poppa should remove some mods. He is modded more .
#785
Hio, which mods is it that you'd like Poppa to remove to make it "mod for mod?" Even though Phil does have more power mods... But I still want to hear from you what you'd like poppa to remove to make it as "fair" as possible.
#786
Phil still on stock clutch? If not, poppa should get a stall
Power mod wise, Poppa should get headers, CAI, and intake manifold on there
We'll call the rockers and the e85 offsetting, even though rockers pick up more on the dyno.
Then Phil just needs some wheels and tires and we're all fair
#787
Lol.....not likely. Very much not likely
Troof
Troof.....the 5br0ginas are really sore over it too.
No it wasn't tuned. If it woulda had as much attention paid to it's tune as yours did this would of been a blow out. Not like we did emergency cat deletes.....claimed it helped....then back pedal on it.
More troofs
Troof
More troofs
#788
Basically from what I've gathered, Hio wants Poppa's car to lose all current power mods & the drag pack to make it fair. Leaving Poppa with minor suspension mods vs Phil's heavily modded 5th gen.
Who woulda thunk it?
#790
Troof
More troofs
Troof
More troofs
#791
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#793
So we are agreeing that the 5th gen was UNtuned for all its mods, and that the TUNED br0 got freight trained up top? Good talk, Mr. Br0jangles.
#794
Rockers and e85 are not off setting. Unless.....poppacry puts stock map in for his cams.
Power mod wise if poppa got headers he would have to put on stock mufflers to be even up. Poppacry has a modded intake set up. Phils is a oe part. Poppacry coukd use a gt350 one to make 100% fair like you want.
Why woukd phil need wheels/tires??? Just put the stock ones back on the mustang. You're actually pretty dumb for not excepting that. The 5gens stand way more to gain with a drag pak as their wheels/tire combo is heavier.
Troofness
#795
Shocker, Hio wants to make the power mods more in favor of the 5G than the Br0
I did the drag pack for the 5G as a courtesy with the power mods the same for both because I knew the 5G would need any help it could get.
Rockers make more power on ls3 than e85 does on Br0s. Poppa wouldn't need stock catback as his 3whp catback gains as much as NPP. So add headers
Poppa can have CAI and Poppa can now have a oem stock gt350 intake manifold. Now we are all even mod wise.
#796
I kinda thought something was odd with the car because the shifts were soft....like it just wouldn't hit the tires hard for the next gear. Running poppacry was good.....you could see it happening plain as day.
It hits the ****** tires now
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#798
Poppacry got back to the oe mufflers just like phil has on his car. Headers would be fine for poppacry then.
No need for anything other than stock wheel/tires here.
To keep it even i thought the gt350 cai would be comparable to the oe z28 cai. Sounds logical unless you just want to cry about something.
E85 likely makes more power than rockers. Like i said poppacry is not running a stock cam map so that's even up with rockers. There really is no need at all for e85.
Should probably scale the cars to since poppacry is lighter. Even **** up a bit more like you want.
#799
So you no want fair? Surprise surprise on that. If poppa would get a gt350 mani then phil would get a fast. Or poppacry can port his oe intake mani.
Phil has a ported ls3 intake manifold, we'll even it up and give poppa a stock unmodified gt350 IM
Nah, NPP Phil listed as a mod and 3rwhp about the same. Maybe a little weight savings for poppa
We'll give the 5G wheels and tires as a charity item. Weight saved would match or beat Poppa's catback weight savings except this will be rotational mass so charity item for 5G due to their inferiority.
To keep it even i thought the gt350 intake would be comparable to the oe z28 intake. Sounds logical unless you just want to cry about something.
Poppa has a stock air box right now, but ok, a gt350 stock air box maybe.
Ls3s make more with rockers than Br0s do with e85. Been proven consistently time and time again. Poppa is just running a tune so we'll give Phil a full fledged tune instead of a modified tune to even it up.
#800
Poppacry would lose now with new tune which is still not perfect. But if Poppacry has light weight wheels,ewp and a converter he will be faster than Phil. If Phil does E85 that would be a really good race to watch. I don't think a FAST would do much if anything for Phil. Next mod he needs is a clutch and driveshaft. I think both of them will all of those mods would be a toss up.
