Bolt on Mach 1 destroys bolt on LS1 Z28
#282
Look....autobitch is back. Weren't you suppose to be gone for life?
So are you saying all the fox 5.0 records are null and void?
Your bolt on car woulda got walked. No 2 ways about it. I beat a faster bolt on 5br0 than you.
Fyi.....i went faster than you with bolt ons with out the rocker and on a ls6 itake.
They accept cam timing changes and rockers on all the furd lists.
Converter is full of oil and bolted to the motor......Good point
Coyotes can use tockers if they want. Nbd
You for sure made it up.
Most ls guys don't seem to like rockers for some reason. Maybe that's why. They have for sure always been bolt ons .
Have you noticed none of the furd guys will discredit the old fox stuff for it?? Lol.......point made
Looks like sw says the 5br0s shouldn't adjust cam timing.
I know he thinks they shouldn't run that 50shot of nitrous fuel either.
Troof
Troof
#288
Yes, they should be void. I don't understand why people get so worked up over this. If it touches oil, it's not a bolt on, the rules are very simple. Of course, it's up to people to make the rules, technically ANYTHING is a bolt on, since it bolts on to the motor. Heads, cams, superchargers, the works.
It sure does seem to.
Lol....commie bastards
#290
Now there are other things in the tune you can adjust besides cam timing. It would be no different than me making a robot to put my rockers on.
The furd guys adjusted cam timing on the old 4v ****. They claimed because furds poodak piles of poo weren't the same on all motors.
50hp shots of nitrous fuel should be out.
#291
#292
#293
I'm simply not allowing that.
How bout that power adder of ftw?
#295
7 Second Club
Hahahaha....Dug really is an inbred idiot retard.
That is all.
That is all.
#296
A fuel is not a power after no matter how much you want it to be. I'm not the one who changed the rules. Petition the guys who make the new fast lists.
The fox **** was before my time, I'm not sure how it was ever considered a bolt on considering its a ******* internal piece.
#299
Hahahahahahaha your a dipshit. Seriously. You will cry and moan like a little baby stip the **** out of everything to try and defend the almighty LS.
