LS3 Vette vs TT 5.0 & Hellcat
#61
#63
I forgot you went the cookie cutter route.....but yea when you were na it woulda drug the **** outta you.
Prime example of someone modding a 5gen that shouldn't be modding a wheelbarrow.
If you think there's that much difference in the cars you're a idiot.
#64
Lol coulda woulda but didn’t. Bolt on, internal mod, caught lying about mods and probably cammed 5gen beats a intake, longtubes, 93 octane mail tune bro on 20s. Damn captain obvious. It’s ok, memory is the second thing to go at your old age.
#68
Worst part is straight line is the only performance metric yalls mustangs would even be close in.
It happens alot. Most have no clue.
You the only one cryin here.....well itstock is to.
#69
You seem to have some tears about to flow. Don't worry.....you and it's stock aren't the only 5br0s it woulda outran.
I always said from the very beginning that I didnt care for an NA bro build in my car, boost was always the goal. I still went out and ran 2 5gen 1LEs and beat them. Would you like me to refresh your old *** memory??
#70
Actually we said no such thing. You're a liar....plain and simple
We said it would be good runs close runs and it was. Remember poppa car had been 11.7@117 at that point plus additional mods since that point. Phils 5gen had no tuning and was riddled with tm.
Fact is all yall didn't think it was gonna be as close as it was. I hardly call 2-1-1 a solid victory either way. One car ran better up top and the other ran better down low. Had a rematch happened with both cars at their peak it woukda looked very bad for poppa on those same runs.
I have no idea about the 1le's you ran. Fact is the cars are a drivers race stock. Wuth m6 cars the driver can make or break them.
#71
Look back then since your memory is always failing, both on video, once was bambi.
#72
It's not like bambi's 1le was some epitome of performance like you guys think. Phils bolt on 1le was quicker. That's not bashing bambi.....it's just how it shook out. So i really don't know what you're trying to say.
Post up your na track times. That easy
#73
Never went to the track with bolt ons, I wasnt bolt on very long. No one said he is/was, but you were saying Phils was. And the races determined that was a lie. You brought the car out, got beat and you started throwing out excuses. Id never do that, if I bring it out its because im ready to race.
#74
I didn't say phils was. The races determined just what we said. The 5br0 wasn't gonna run off like yall thought. It hurt you guys to know that with poppa having one if if not the best 5br0s in the country for its mods that a lowly 5gen could run with it.
This is **** your making up. Phils 1le had never been to the track before he and poppa ran.......so how woukd we know??......nuff said there
We threw out 0 excuses. Those all came from the furd side. Runs were close.....just like we said. We took them as a learning point. Had that car been tuned when they ran it woulda been 4-0 phil. You should be glad it wasn't.
#76
Had good runs. Won 1 lost 2 shorter runs and tied one. Pretty damn good out of a untuned fatgen imo.
One thing we did prove was the ls3 was stronger up top. Even with all the tm.....which holds it back more down low because it don't have time to bleed it off smoothly between the early gears. So no momentum could be gained down low. ....which sucked and woulda easily made the difference in those runs.
Great part is if they had never ran or if phil woulda won them all then probably woulda never dug into the tm as mutch as we did. There's alot in there holding those cars back.....and probably very much the reason they got a bad rap.
#77
#79
Wasn't tooned right??.......how bout not tooned at all.
Seems the only issue here is the fact the 5gen showed up and did well. It was also faster than either of your bolt on cars
