Street Racing & Kill Stories Basic Technical Questions & Advice
TT Flop Gen 1LE vs 6th Gen ZL1 1LE
Old 10-13-2018, 06:06 AM
  #61
BlkMach1's Avatar
Irrelevant to Hio’s argument.
Old 10-13-2018, 06:17 AM
  #62
UltraZLS1's Avatar
Originally Posted by Poppacapp
Meh.. again... simple dropin pistons thrown in while motor is in the car will take you over 1000. OEM rods are good for it
While you might as well do the pistons if going into the motor. Ive read from some in the know argue that it is the tight ring gap and that the stock pistons could handle well past 700 rwhp with re gapped rings.
Old 10-13-2018, 07:18 AM
  #63
automach1's Avatar
Originally Posted by HioSSilver
ls7 is truly bolt on.
you shoulda tried to leave the 13s na in your 5br0
lol....pos triton wouldn't make to 450. Do it....prove me wrong.
Hell your ***** *** still ain't ran that pos 5.4 truck you have. You were supposed to do that.....just alot of mouth is all you are.
My POS Triton > your ls7.
Old 10-13-2018, 08:05 AM
  #64
HioSSilver's Avatar
Cool....give na a try unless pooossaayyy. Na is a mans game tho. Actually shows what the engine can do vs what your power adder can do.
Old 10-13-2018, 08:19 AM
  #65
automach1's Avatar
Always with the stips. Nothing keeping you from putting a 2650 on your ls7.
Old 10-13-2018, 09:20 AM
  #66
ddnspider's Avatar
Received 1,737 Likes on 1,298 Posts
Originally Posted by automach1
Going to take more than a grand said and done. They are hit or miss regardless of mileage. I personally think ~550 is the reliable limit of a 100% SLB 5.3 with a turbo combo.
I normally like your posts but this 1 is way off.
Old 10-13-2018, 09:53 AM
  #67
kinglt-1's Avatar
That is correct...the Piston material used in the LT1 is the same as the LS3. The difference is the ring gaps. You can regap the rings just like a 5.3 LS and it would hold some power, but most will opt for a set of drop-in slugs being it makes more sense if taking the engine apart. That being said the SBE LT1 still will hold more power then most give it credit for. There is a gal on FB with a SBE F1a94 car making 850.
Most places I have talked to said the rods are good for 850-900... Then above 1k you should stud the mains. Other then that the block and crank will handle some big power.
Old 10-13-2018, 09:58 AM
  #68
automach1's Avatar
Well to be honest I am sure there are a few truly untouched 5.3s living at ~800 however that is not a reliable power level for them. Espeically for the older 5.3s.
Old 10-13-2018, 10:13 AM
  #69
ddnspider's Avatar
There are plenty out there way above 550whp and living. I tuned a friend's SBE 5.3 that he daily drives.....just did 19psi on a 78mm turbo on 93 pump gas only....he's got over 10k miles on the setup. The tune has to be right for it to live....which can be said about anything.
Old 10-13-2018, 10:19 AM
  #70
ohioborn80's Avatar
Highest I've seen from gen 3 coyote and still living is 1100whp. Through A10 trans. Haven't seen no lt1, lt4 doing that yet on stock engine.
Old 10-13-2018, 10:25 AM
  #71
ddnspider's Avatar
Truck Doug just posted on here with a SBE 6liter that was over 1000whp.
Old 10-13-2018, 11:24 AM
  #72
automach1's Avatar
I am talking truly SLB cars. For every 1 800+ combo there are 9 others that go boom making less than 800.
Old 10-13-2018, 11:30 AM
  #73
ddnspider's Avatar
Should probably clarify that next time since pretty much everyone talks about SBE not SLB. I'd be willing to bet the majority of those 9 others blew up cause rhwir tuner didnt know what they were doing, not from an actual failure of a component due to weakness. Lifting a ringlands is the number 1 failure of all LS high hp stuff and it's mainly due to tuning.
Old 10-13-2018, 11:56 AM
  #74
kinglt-1's Avatar
There are LT4's up in that power range.
Old 10-13-2018, 12:45 PM
  #75
HioSSilver's Avatar
nothing keeping you from backing up your mouth and running na. If that 4v turd is so great it shouldn't be a issue for you to run what my ls6 ran. But we both know it won't.
lol....99% of his posts are way off. Now just wait for stip he'll spit. Ooopps...to late
that's because erryone thinks they have to shove a cam or do the heads on a ls. The engine is plenty capable with out that.
Old 10-13-2018, 12:51 PM
  #76
UltraZLS1's Avatar
lt4 is over 1500 hp on sbe
Old 10-13-2018, 01:00 PM
  #77
automach1's Avatar
Well pulling it apart and installing a different set of 5.3 rods, arp hardware, etc... doesn't constitute as "stock motor".
Old 10-13-2018, 01:05 PM
  #78
automach1's Avatar
If I sold blower stuff and went with a legit all motor combo you wouldn't have a chance. Nice stip though everbody that is fatser than you with a power adder tell them to go n/a lmao.
Old 10-13-2018, 01:21 PM
  #79
HioSSilver's Avatar
You had a legit motor combo. You got rocked hard core like all while I'm still ******* with bolt ons.
but yea you would need a legit motor combo to run with me only with bolt ons. And the ls6 never got ran in it's best form. You would need a custom errythang to even attempt to run with a bolt on ls7.
Old 10-13-2018, 01:22 PM
  #80
LS1Tech Premium Sponsor
tech@WS6store's Avatar
It's a modular motor.
Kinda like how the 1993 camaro and a 2016 corvette have the same engine right? They are both LT1s.
