02M6SS vs 18 10sp 5.0
The size of the master matters. If the one you have is larger than stock it will hurt drivability.
I have made several pedal stops. I make them adjustable and bolt them to the clutch pedal. They really help a quick clutch drive better.
Reducing the throttle cracker or eliminating it in the tune helps dramatically to.
I've noticed a dead zone at the top of the clutch pedal where it hangs maybe an 1/8"... That could very well be it.
Otherwise it shifts like no bodies business...
Sweet good luck. I wonder if I could get that to work with a stock SS hood. Great idea! Hope it works out for you
Did the butthurt from Jake give you all of that premature gray hair?
#32
My car is far from a bolt on car... lol
Full moly suspension, tubular K, MWC 9", drag bar, Vikings at all 4.
Cam is custom, smaller than most. According to Julio at Cartek, it's the largest that could be run on his 243's without fly cutting.
Also has Kooks 1 7/8 and their TD.
Hoping to crack 10's on a slick this summer after I get my Mamo FAST 102, 4" MAF and EWP.
#33
#35
#37
If you want to compare fatass to fatass, we can do that too.
Cam/Exhaust/Stall/DR GTO vs catback S550 Mustang...
#39
#40
"Probably a V6". Then that GTO "probably had 2 dead cylinders". Nice try, bitch boy. Anymore excuses for that 15 second 5.br0?
