Epic SRK B/S thread of 2019
#3581
#3582
7 Second Club
#3583
#3586
7 Second Club
#3587
7 Second Club
Likely send it to my tooner and see what he says. (yolo-dbag has been dealing with me as of late).
PS. Wait until I put on the road race setup and get a 1.26. lol
#3588
7 Second Club
#3589
So you think if he took the power adder off he would go as fast.....weird.
Backed it up with a 10.9. Delta of less than .2. So you lie once more bitch.....and way faster than your bolt on 5br0
Sure they can.
Road race set up typically has more control for the chassis. I'm sure you wouldn't put less control in it to go faster right now.
#3590
7 Second Club
#3591
I'll tell ya what. The times either or all of us have run in the past dont amount to **** if we cant grab the keys and go do it again right now. Your car is broke, or your *** is broke, or whatever. I sold the Evo. I'm working on my putting my SS back together. im putting it back together initially NA on pump gas. What was your best 10 second pass? We'll see who goes faster with all else being equal.
Btw....I found .3-.4 in that car after that track outing. If one really wanted to get aggressive with other **** that .6 was there.
Actually the car is perfect other than the water in the oil pan issue. I'm not broke so I'm doin ok. Thanks for the concern.
The only trolling was me watching him own it and you backing him up. Just showed what bitches both of you were.. are.
Nothing gonna change the fact that you a bitch.
And you -20
#3592
The ones that got trolled congratulated him. I'm not the only one that asked him who was driving and he didn't want to answer that. He was asked him on kik and zoobitch wouldn't answer.....had s bit of a conniption on there to.
And you -20
#3593
You had 4 tires touching the ground pulling your ***....a 1.8 sucks.
I had four tires spinning in the middle of second gear. Not much pulling/pushing to be done when they are spinning. If you cant get that I now understand why you cant comprehend the differences in ET.
10.7@129.8 pump gas , driving to and from the track on a rain worthy tire. No gutting...normal dd **** in the car. Bolt on ls6 with a m6. I mean I'm sure someone could build something to go faster....it has been done. You probably can't but idk what the big deal is.
So 10.7@129.8 is what you want me to beat on pump gas driven to and from the track? Gotcha. Is it ok if I do that with a less displacement truck motor in a full weight full accessory car?
Was it in the glovebox or in the trunk?
If nothing else, you gave me something to shoot for on version 1.
#3595
7 Second Club
#3596
Not bad!? That's crazy for 3800lbs. Just out of curiosity, what were the DOT tires you were running at the other event?
#3597
7 Second Club
#3599
7 Second Club
#3600
![](https://cimg3.ibsrv.net/gimg/ls1tech.com-vbulletin/1024x768/dy4hoi4xqaajsc6_1dbb76174510e5e96f3c4171ca98ad476fb0812f.jpg)
Hio trying to explain how his times make sense and landers dont....
