Epic SRK B/S thread of 2019
#6901
I would have to assume its high 7's low 8's at a minimum. Considering the SBE L33 fox body went 7.7X with a 2900lbs race weight. Which is on the light side but I would say doable for an fbody.
#6902
It was in a fox. Easy chassis to go fast in no doubt. The owner name is Jonathon Capizzi maybe google can help?
#6903
Hio didn’t post any car
You posted a Fox with a 5.3 and not a stock trans (I’m guessing)
No?
Now the YouTube Coyote video I just ran across was not comparable to your fox ls built trans hybrid.
Im wrong posting a 6.99 Coyote stating stock block thinking sbe in vid
#6904
If I’m wrong I’ll be the first to say it.
No?
Im wrong posting a 6.99 Coyote stating sbe in vid
No?
Caprizzis car is a SBE LC9 with a Glide, borg warner S480 iirc
#6907
No?
No?
#6908
It becomes more about what fuel you're gonna run and what boost applicator you're gonna run.
Alot of these boost applicators from the factory are centered around packaging that can limit them and a compression ratio to deal with pump gas. Hence why i asked if there are any factory blower furds in the 8s? ??? How bout in a package that was available 5 yrs ago for the vette and 3 yrs ago in the camaro?
Then do it on a puny 1.7 blower instead of blower of choice. You're talking out of both sides of your mouth here. You want factory hardware but then you come up with some bs that don't match that at all.
#6909
you must be getting a hell of a hookup on a 427 lt1 then. The tsp short block starts at basically 8k with non arp stuff, add the good stuff and its over 10k. Then add all the goodies for bolt ons, ported heads, highram or msd, etc and your close to 20k pretty fast. Like a clutch to handle all the added power.
#6910
Texas Speed lt1 car weighs under 3000lbs too that just ran 9.2. Its got basically every high dollar suspension part and drive line known to man. And isn't on stock gm computer either.
Gpi car is said to be lighter too, plus that 5k stall helping it move
#6913
7 Second Club
#6915
#6916
be a gpi build I’m doing also got hi ram for $700 looking to keep it under 12k if possible I figure I’ll need driveshaft and axles though to .
The following users liked this post:
islander033 (05-26-2020)
#6918
HioSSilver (05-27-2020)
