Street Racing & Kill Stories Basic Technical Questions & Advice
Chevies worst motor the 305 vs fords best motor the 302
Old Aug 4, 2025 | 06:30 PM
  #81
NA4VSVT's Avatar
Originally Posted by HioSSilver
The stupid **** you say is definitely consistent
I've set the guidelines bitch boi. You just keep trying to look for a way out. I guess your way out is just not putting anything together.
So you are still set on making up arbitrary guidelines to avoid the race 😂
Old Aug 7, 2025 | 07:28 AM
  #82
big hammer's Avatar
What’s the difference in bore size between a 305 and 5.3
Old Aug 8, 2025 | 04:00 PM
  #83
01CamaroSSTx's Avatar
4.8 & 5.3 is .044 larger
Not much of a difference in bore and stroke of 305 to a 4.8
Old Aug 12, 2025 | 04:20 PM
  #84
big hammer's Avatar
correct pal
yet they’ll pull 8000 no prob for some reason
Old Aug 14, 2025 | 07:30 AM
  #85
snake95's Avatar
You have to have something to lock in.....and you don’t. Been 14 months of you just crying like a bitch
You lost that. Once corrected for the yuge difference in DA you lost.
Didn't you run like a 15
once again what does anything to do with my car have to do with this thread?
Besides there's nothing outlier about that.....besides the fact the car actually put the power down on that pass.
I own prime real-estate in that puny mind
Nope my stock 302 beat the 5.8L GM car.
but you said the bigger engine made it slower or some other iteration of ricer math that you only use when the GM car loses.
Old Aug 14, 2025 | 04:30 PM
  #86
HioSSilver's Avatar
but it didn't. Corrected times and you lost.
Stands to reason if one installs a larger engine especially from that era that it wouldn't go any faster on a stock tune
Either way you lost
Old Aug 17, 2025 | 07:24 PM
  #87
big hammer's Avatar
GM ftw and im not even a fan
Old Aug 21, 2025 | 02:49 PM
  #88
LSux's Avatar
just a fanboi
Old Aug 26, 2025 | 07:02 PM
  #89
HioSSilver's Avatar
me neither anymore. Their old stuff was great
Old Aug 26, 2025 | 11:39 PM
  #90
Mike Morris's Avatar
Ford superior modded
Old Aug 27, 2025 | 11:43 AM
  #91
LSux's Avatar
You're into the new Jags aren't you? Be honest
Old Aug 31, 2025 | 08:50 AM
  #92
Old Sep 1, 2025 | 06:37 PM
  #93
HioSSilver's Avatar
Not at all. Their only real chance is bolt on . They get fucked right in the *** once past that.
you seem to be
Old Sep 2, 2025 | 07:31 AM
  #94
LSux's Avatar
you seem to be
The one in the yellow up front could be your uncle mommy.
Ford cast heads, Ford cast block, fully functional cooling system.
I guess it’s pretty much bolt-on by LS standards, it’s a comparable level of build to your 11 second 347 after all.
Old Sep 2, 2025 | 03:11 PM
  #95
you seem to be
No. Better bottom end more aftermarket and way easier. Owned both.
TPI prices were insane and ever worse now. Plus Mustang has that 8.8 rear.
HiHO one argument you cant win unless wr throw 89 turbo Ta in mix
Old Sep 2, 2025 | 03:15 PM
  #96
LSux's Avatar
He can't win any arguments in this section.
Old Sep 2, 2025 | 04:41 PM
  #97
wannafbody's Avatar
I think the 351 Cleveland was a better engine than the 351 Windsor. And I don't know why, maybe firing order and maybe a set of Flowmasters but those roller block 5.0's just sounded great.
Old Sep 7, 2025 | 08:33 PM
  #98
HioSSilver's Avatar
Well i guess there's nothing holding you back from duplicating that.......so go do eeettt. Easy peasy
Or maybe it’s just not what you claim.
Turbo ta was even more expensive than tpi stuff.....and they only made 1k if them.
Coyotah doesn't have a better bottom end tho.
I've won all of them.....to the point you dumb ***** can't even build a furd to keep up
Windsors were gigantic turds. sbc thoroughly beat them the **** up.
Clevland was powerful but didn't stay together very well.
Old Sep 8, 2025 | 06:33 AM
  #99
LSux's Avatar
I can replicate the powerplant and the power easily.
Name a single, solitary point you've won.
Old Sep 8, 2025 | 10:16 PM
  #100
LSX tall deck dominates every engine Ford has put out since it's debut. Ford fails to compete with GM"s pushrod engine. It was proven that the DOHC 5.0 couldn't make the power or even stay together in a forced imduction horsepower shootout with GM's LSX engine built by Late Model Engines. If only GM would've came out with a DOHC LS engine but I guess they didn’t need to.
LSX tall deck built to 454 running on 91 octane will outperform anything Ford has put out in the last 20 years if not more from a performance standpoint. Ford has to supercharge to be relevant but throw a blower or turbo on the LSX and it'll beat out the Ford engine every time.
