Racing in 3rd gear....
also known as gear selector D, you will run out of gas at 125 mph as I have in my Z28, that's when, then you want to move the gear selctor -in an auto matic- to (D) a.k.a. 4th gear and walk the other car down other wise you will stay at 125mph or so.
I once raced a 2003 Lexus ###'s something, something - the 2 seater, the one that are corvette price and looks like a two seater -, anyways I had just gotten into a main road and only he and I were on the rode - upon entering onto the road I took the turn fast on to the road - and this Lexus that I was about to pass hit the gas. I noticed this so I stepped on it too and with in few seconds we were a 125 mph, he keep his lead. I was at his rear quater panel and I was stunned and confused as to why I could not get past 125 mph. So I let off the gas then stomped it to the floor, it now pulled me next to his door mirror, but still I could not get past him or 125 mph, I was staring with amazment at my mph gauges. So he shuts it down then I do the same. So Im know entering the freeway and thinking about what just happened, 'why would my Camaro not hit past 125mph?'. I then find this site and later on ask a question as to why did my car not respond faster then 125 mph.
When I mentioned that I was in gear selector D, I got a respond that gear selectore D, is 3rd gear and I had ran out of gas and should have shifted into (D) a.k.a 4th gear for more mph. Then it all made sence. Because even before this one race, I would like to drop to gear selctor D and when i felt like the car didn't pass 125 mph I let off and thought something was wrong, never nowing I was out of gas -mph- in 3rd gear. Know I keep her in 4th gear a.k.a (D) every since and no problems now winning a race.
I know a lot of people already now this but some may not know that 3rd gear a.k.a, gear selector D, runs out of gas at 125 and that's when you want to shift up to (D) a.k.a. 4th gear . Hopefully this is useful information.
But isnt it true that some stalls kill your opportunities to race on a roll? I read that somewhere before...That a stall was great from a dig but, depending on the stall rate, may be hurtful from a roll.
Originally Posted by z98
Stall should make racing from a roll MUCH faster.
Also, what gears to you have that your 1:1 gear is running out at 125?
You are lying. 3rd gear in your car should good to over 140 mph. If you are hitting the 125 mph speed limiter, you have never been to 153 mph.
Some one mentioned I should have been able to hit up to 140 mph in 3rd gear, well from my experiance my car -repeat- could not go past 125mph in 3rd gear.
Why the Lexus didn't go faster since he could have according to car and driver specs? I belive he was contemp with the lead and nowing he still had some more gas/mph left.
Have you tried maxing out 3rd gear in your automatic LS1 Camaro?
you are either A:lying or B:stupid. the 1.1 ratio of a 4l60e trans 3rd gear coupled with a stock 25-26" tall tire and 3:23 gears should allow you to hit between 142-146 before you hit the rev limiter and would need to shift to 4th depending on which tire height you have. do the math thank you and pay at the second window.
here to make it easy for you click on the link go to calculate mph for rpm and enter a 26" dia with a 3.23 and voila you can see you're wrong.
http://www.speedworldmotorplex.com/calc.htm
Are you talking about a fuel starvation problem in higher <sustained> RPM's? Clogged fuel filter, weak pump, dirty injectors/filter?? I have an auto A4 that has seen well past 125 in third.
