Street Racing & Kill Stories Basic Technical Questions & Advice
EVO vs. LT-1
Old Jan 10, 2005 | 08:02 AM
  #61
CarsRFun's Avatar
dont underestimate the EVO's, they can surprise you real quick.
Old Jan 10, 2005 | 10:47 AM
  #62
wickedwarlock's Avatar
Originally Posted by DomesticRice
Thanks for the obvious comment.
What I intended to say was that EVO's have VERY good potential from the factory. They come boosted already and has AWD. Cams, internals, turbo upgrade and some other knick knacks will make it push over 400WHP easy and be able to run sub 11's and break 10's.
What I'm trying to say is that these cars are not to be taken lightly.
You're welcome, that's true for anything.
400whp, it's not going to break 10s on factory weight. 3300 pounds plus fuel and driver. It's not but no doubt 11s. Upper 400whp, possibly with a good launch, than watch out for breaking something.
Old Jan 10, 2005 | 10:48 AM
  #63
This is so true! So can a wrx or sti. hell, I've seen a couple of fast 350zs.
Old Jan 10, 2005 | 12:08 PM
  #64
99badta's Avatar
Originally Posted by EvilDylan
interesting, i just got a dyno with cam gears, and i gained 51 whp with tuning and retarding the timing on the gears.
You got most of that power from the cams, along with your supporting mods. How much r u putting down now?
Shane
Old Jan 10, 2005 | 12:09 PM
  #65
99badta's Avatar
From what I saw at the shootouts this past season the regular WRX guys were killin the STI guys. And no doubt a 350Z can be fast but very rare to find.
Shane
Old Jan 10, 2005 | 01:10 PM
  #66
EvilDylan's Avatar
Shane
i dont have cams.
on a dynodynamics dyno 275/275
which is supposed to be about 10% lower than a dynojet.
Old Jan 11, 2005 | 06:30 AM
  #67
Shane
I don't doubt that about the wrx. There was more aftermarket available at the time.
Old Jan 11, 2005 | 09:42 PM
  #68
diambo4life's Avatar
i dont have cams.
That just doesn't sound right. You picked up 51WHP just from dialing your stock cams or am I missing something else that you said? On what car is this again?
Sorry, I know it's .
Old Jan 11, 2005 | 09:53 PM
  #69
Vendetta's Avatar
Shane
All it really takes for a WRX to surpass stock STI power to the ground is a turboback and a tune. Of course, the STI takes much better to mods due to it's added displacement.
Old Jan 12, 2005 | 07:55 AM
  #70
EvilDylan's Avatar
Sorry there was confusion.
I installed cam gears and they were used, i did not know that if you put the 0 at TDC it would actually be advanced 7.5 degrees. SO what i thought was a 7.5 degree retard was actually just setting them back to 0. SO tip to evo owners, DONT advance your cams cause it makes you lose crazy HP.
Old Jan 13, 2005 | 12:41 PM
  #71
MonmouthCtyLS7's Avatar
If your running long tubes Id say you'd take him...evo's generally run mid to higher 13's stock
Old Jan 17, 2005 | 11:33 AM
  #72
cardude777's Avatar
ive raced a stock 05 wrx sti which is evenly matched to the evo. i have a stock 2000 z28. i beat the sti by a caror so. so i think that the race between an evo and mod. lt1 should be pretty close. just feather your clutch on the launch and be sure not to spin.
