foxbody vs. ls1
#141
Originally Posted by mattkimsey
Show me someone who has ran 12's in a full weight 5.0 with nothing but a gear and slicks. It may have happened, but it's probably as rare as a 12.6 stock fbody. In fact, I've never heard of such a claim. Cosby ran 12.99 in a coupe with a few more mods than that, but we all know he is a 0.001%'er.
Are you sure about that? An off the shelf H/C/I car is going to put down 280-290rwhp while keeping emissions and accesories. An fbody would make slightly more power. The only thing seperating the two would be weight. If you compare hardtop to hardtop we're talking about 200lbs give or take a few. I'm at Corral often..
Really if so why do you seem so in the dark about Mustangs. They have more advantages on F-Bodies than weight. Yes a 280 rwhp Fox is going to be faster than a 300 rwhp F-body. Probably not from a 100-150 mph roll, Ill give that but its going to out 1/4 mile. You can put a slick on both if you like.
Why use one car? That is why I said take the average of multiple test. Key word is MY...your individual results may work for you, but it should be repeatable by many others.
As a matter of fact, I do have a 90 LX 5.0. It's isn't running on it's last leg either with 90k babied miles. I know plenty
No, I'm not calling you a liar....it may be true for you. But, for me and others I know and see on the net, it's not true.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#142
Originally Posted by Sukkoi19
If you read my previous post on the matter I clearly stated more than gear and a slick, I rounded for the sake of less typing in the last post. Yes sure theres other crap you've got to do but none of it is modifying the long block.
Note where I said that it for sure was a rarity. I believe I specified that numerous times in this thread. And no I cant remember specific examples, I said previously "I remember back in the day when the recipe for 12s was..." Saw it happen once.
Unlike mag racing I was using a real life example. Seems to work out much better that way. That way I know the actual conditions of the test.
Then if you have so much personal experience why do you feel the need to mag race? Maybe you could have said something to the effect of "Well my LS1 tears up my 5.0L" then instead of angering me with ricetastic mag-racing we could have agreed to disagree.
#143
Originally Posted by Slow Vette
u have 2.73's? cause 0-60 is first gear alone
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
