LS1 Smackdown!!!
Originally Posted by Smokinstorm
Bring that LS1 Killer down to Northeast Dragway in Elizabeth City this Friday night. I've got a stock LS1 that's just itching to get its *** handed to it by an LT1. Come on down and scratch it. I'll even bet a little money on it if that's what it takes. The superior low end power (and top end power according to your post) of your LT1 should have no problem whatsoever taking my inferior LS1 in the 1/8th mile, right???
Mods to my car: Converter, 3.90's and tires. No power enhancing mods.
Let me know if you're going to make it so I'll be sure to get up with you.
With the temps in the 60's this Friday night I'm hoping for some 7.7's in the 1/8th or if I'm really lucky a high 7.6. The car has been 7.8's in the heat. I was getting some headers installed but I called them and told them to wait until after this Friday night as I want to see what my stock motor'd car will do in better air before modding the motor.
I compaired the advantage of the intake design to the intake design on the LS1 big difference.
Everyone knows the LTX intakes do nothing. Wich is why guys who are running in the 10's usually dicth them all together. Take a look at Joe overtons setup for example.
how you get air to the heads is everything, and the LS1's already have a more advanced setup in that department. I've stated that numerous of times.
See as that I'm more modded than You I no longer wish to argue with you... you are beneath me.
The End.
To the guy who said the gap was 50 and not 25... thank you I already corrected myself earlier in the post.
To the guy who want me to come to NC to beat him.... hell come to Va.
what are my cars actual specs?
Don't worry about it... enough to keep you behind me.
Just from this thread alone my blood pressure has raised. To believe most of you think the LT1 is an inferior motor because it came will less hp from the factory.
And the fact that most of you have less mods than me.. and think you can beat me.... where not on the same side this is a Civil war and it always has been.
LT1 Vs. LS1 Shootout.... someone go find me the results from that battle.
