98 camaro ss vs 03 mustang gt
#61
Originally Posted by REDSS01
This race outcome will look something like this:
http://video.ls1tech.com/player.aspx...1-C7CF5867C585
I'll race that guy with my GTP. That would be a closer race. Your SS will kill it.
#64
http://www.stangpro.com/html/articles/Bullitt_Dyno.htm
Here is a dyno you should see. 2000SS and a Stock Bullit mustang (rated at 5hp more than GT, mainly suspension mods) as well as a 99Cobra with the fix done.
#65
Originally Posted by mattkimsey
Maybe he's scared of getting beat by a car with $75 in mods??
ok now i'm scared of a 30k dollar car vs my 20k dollar car get real...its for fun..he brought this to the forums for you opinion becasue hes scared and wanted a bunch of chevy guys telling him hed win...i on the other hand will be happy just posting the video..
#66
I am changing my vote to the mustang GT because the power the two cars have is close and even though the LS1 has more under the curve, the GT has 4.10's to help it get to the right part of its power curve and once it gets there, it will be easier to keep there b/c its a 5-speed. The GT is prolly in the 270-290 rwhp range. It is probably withing 20rwhp of the ls1 and weighs about 1-200# less. That means hp/weight they should be identical with the GT having better gears/tires. I think the GT will win this one. Not by much, but im changing my opinion and having to say the GT has better odds if the guy can drive. If not, i give it to the A4 ls1
#67
#69
we are talking 410 gears in the stang and i think my ss has 373 s is that much of a difference he does have 18inch rims and it was a dog from a dig
#72
If your SS is stock it came with 3.23's, you ca check this by looking at the codes stickered in your glove box or on your driver's door. If you se a GU5 code, it has 3.23's if you have a GU2 code you have 2.73's, GU6 is 3.42 (normally in a M6 car)
#79
Gear swap will run you around $700 because you must swap out the carrier in a GM car to go from 3.23 to 4.10 if i am not mistaken, also you must purchase gears, have them installed, and get your ECU re-calibrated. I am not sure about teh carrier issue though, can someone enlighten me?
#80
ok my guess is enough has been talked about for this match up...gonna just have to run and see what happens...look for a post next saturday..."Stang spanks SS"
