What would it take to beat a NEW ZO6 ?
#61
Originally Posted by 996TTx50
This should do it:
Now I just have to find a C6Z.
996TTx50
996TTx50
PPPPPPPSSSSSSSSHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHh
sexyyyyyy... and I remember you have quite the mod list to back that ****** up too...
#62
9 Sec. Club!!!
Originally Posted by LS1-450
Wow, low 11's are more than pretty good then. How much spray...150 shot?
#63
Originally Posted by dan03mach
It's jetted for a 125 shot but I'm getting a little over a 100hp to the ground.. On the N20 it's putting down a little over 430rwhp.. and over 500rwtq..
Good numbers & great driving to match. That engine is also breathing well.
Pretty cool actually.
#66
Originally Posted by unit213
Modlist? How much power is that best cranking out?
Performance Mods: EVO MS GT800 turbos (Garrett GT35 compressor / K24 turbine) * Custom GIAC programming with Chipswitch (valet, 91 and 100 octane programs) * La Bree Motorsports custom exhaust (Tubi tips, Burns Stainless Ultra-Light Racing Mufflers, 76 mm 304 stainless steel tubing) * EVO MS short tube headers (44.5 mm primary tube, Tech Line Turbo X ceramic coating) * Bosch/Siemens 720cc high flow fuel injectors * Bosch high pressure fuel pump * Gemballa sport air intake system and air inlet distributor * GT2 intercoolers with Innovative Pro Design modified end tanks and piping * Innovative Pro Design aluminum Y-pipe * 996NA 75 mm throttle body * Innovative Pro Design aluminum intake plenum * EVO MS V-Flow intake box * Aquamist methanol/water injection system (boost actuated direct spray into the intake) * Aquamist methanol/water intercooler sprays (boost and manually actuated) * Kenne Bell Boost-A-Pump (fuel pump voltage amplifier) * Porsche Motorsports 5 bar fuel pressure regulator * EVO MS fuel line upgrade kit, including stainless steel lines, modified fuel rail, and fuel filter * EVO MS silicone boost hose kit * Bailey diverter valves * Carrillo rods * IA 8740 alloy, coated head studs * IA upgraded, coated valve springs * GT3 oil pump * Shuffle pinned case * Ceramic coated piston tops * Dry lubed rods and skirts * Porsche 986 MAF * JRZ RS double adjustable racing dampers * Eibach springs * TPC front and rear sway bars (24 mm/30 mm) * TRG front and rear adjustable drop links * Cargraphic alloy strut tower bar * Brembo 14in / 380 mm Evolution brakes with cross drilled rotors * Brembo wheel carriers * Brembo stainless steel brake lines * Brembo ceramic brake pads * Porsche X50 transmission * EVO MS modified torque converter (increased stall speed) * HRE 540R wheels (11.5/8.5) * Michelin Pilot Sport Cups (315/235) * Optima Redtop battery
Non-Performance Mods: Tech-Art Type II front bumper * GT2 rear wing * Porsche sport seats * SmarTire tire pressure monitoring * AEM wideband air fuel gauge * Defi-Link boost gauge * Defi-Link Control Unit II * K40 radar detector and laser diffuser * RUF stainless steel pedals * Carbon fiber steering wheel, shift **** and parking brake * Silver Porsche crest * Paris Audio garage door opener * Chrome lug bolts * Bumper plugs (front bumper and driver's keyhole) * Rear wiper delete and plug * Clear side markers * Ash tray delete console * 35% tinted windows
996TTx50
#67
Approximately 950 hp (guestimate).
996TTx50
996TTx50
Will you adopt me.........................Dad?
#70
996TTx50
996TTx50
#71
Originally Posted by 2000 SILVERADO
What times are you running with all of that?
That car would be damn near unstoppable on the autox with a good driver though Which is something I fully respect
Out of curiousity, what is the redline and theoretical top-speed on that Porsche?
#72
996TTx50
#73
Administrator
I have not taken it to a 1/4 track. I do not have a roll cage and I do not want to drive multiple hours for a single run.
996TTx50
996TTx50
not a drag car. The trap speed would be ridiculous though providing
you could find enough traction to stay at WOT.
That must be insane to drive on the highway from a 70mph punch.
#75
#76
Realistically, it wouldn't ET as well as many of us simply because it's not a drag car. The trap speed would be ridiculous though providing you could find enough traction to stay at WOT.
Highway punches are awesome!
My car was designed for the street . . . it is a daily driver.
996TTx50
#77
Originally Posted by Camaroz
Can you even go WOT on the street
996TTx50
#78
Sure, as long as you have some open road in front of you and you keep both hands on the steering wheel when the tires break loose.
996TTx50
996TTx50
#79
Originally Posted by mattkimsey
In other words.....1 million dollars
and it is NOT a daily driver. there is no way you could ever begin to convince me you drive that thing every day. im not sure ANY 911 owners daily drive their stock porsches let alone a modified one. that is not to say it couldn't be daily driven but don't go saying it is the daily for you.
im guessing a mid-low 10 but 145mph traps, just a shot in the dark and yes it would take a ls7 z06.
im also not all that jealous, since i'd be afraid to even drive that car for sheer fear of getting any scratches/dirt on it, potholes, deer, and other drivers. i could not enjoy owning that car it would give me a nervous breakdown worrying about it.
#80
Well to give you an idea. I raced an M6 C6 from a 45 roll and was dead even till 4th when he put 5+ cars on me. I was running high 11s in my auto, and that was just a C6 and not a Z06.
