Kennebell Goes down!
Originally Posted by JayplaySS2
You should be happy with it, you have a badass car man. I miss my 99 SS at times.
Thinks, do u ever come around Tampa? We can go out and mess some people up if u do.
I can't even get him to come out right around the corner. Busy man.
Originally Posted by unit213
Good kill!
Tell him to spin that thing to 21psi and run racegas. Honestly, there's no point
having a KB if he's only going to run 15psi...might as well of kept the Eaton.
Exactly what he needs to do.. i'm running 20psi... whole different beast !
He's turning the boost up to 19psi so it's going to be fun.
He might get to the point that he can't hook the car, or has trouble hitting clean shifts.
I'd say you'll still get him.
On a side note...it's cool to talk **** about this stuff without dealing with a bunch of internet fucktards like on LSx.com.
S.
Originally Posted by Snorman
Yeah...but your car probably works very well with that TH350 and spray.
tire, I say you'll walk him.
He lives by me so we are friends. He has 11 inch cobra rims w/315-35 nitto drag radials. 8.8 rear w/stock 3:55 gears. Tubular k-member. no front sway-bar, Qa1's and it's got some springs I didn't ask what kind. I talked to him today and he said it put down between 530-540rwhp when we raced. I'm on M/t drag radials so I might be ok i'll just play with my air pressure.
Tell me about it. I have had time to go to Towers once in the last year!
That is too busy.
Yo,...just rear last night at a buddies house a MM&FF mag with a twin turbo kit BOLTED on to a 03 Cobra, tuned witha diablo sport programer,.....@ 24psi the car made 857RWHP . All stock, except for the turbo kit itself. ******* bastard ****** and your factory forced induction motors.
Originally Posted by 00firebird
why do the KBs need so much boost? 22 psi i think they're made for and they put out about 600-650 or so. 22 psi into an ls1 would be like .. well over 800 hp id imagine.
And 22 psi into an LS1 would not be "well over 800 hp", it would be more like a scattering of engine parts. However, assuming it could live, 346 c.i. and 10.5:1 compression would obviously make more hp per pound of boost than 281 c.i and 8.5:1 compression.
Originally Posted by gnxs
KB's (or Whipples) don't "Need" 22 psi. You can make 600 rwhp at 17-18 psi.
Ok please correct me if Im wrong but if you want to build a high boosted LS1 and do it safely you would want to lower the compression and naturally building the motor? By lowering the compression you WILL lose power, compare a 01 Cobra with KB 8-9PSI to a 03/04 Cobra with 8-9PSI The 01 has higher compression and will put out more power but won't be as safe as the lower compression as the 03/04. One reason why I hate to hear the comments about what a bigger higher non forged motor can do with the same boost.... Dumb comment IMO!
If GM were to have SC or TC an LS1 from the factory Im sure for reliabilty purposes they WOULD lower the compression and lose NA power to make FI power.
Correct me if Im wrong....
Originally Posted by Joegt38
BTW nice kill its not your fault he brang a low boosted KB thats what he gets...
Thanks and i know its no 21psi KB car but very happy, it was my first race with the Trex cam
I can only imagine what some guys think rolling up to a light with a T-rexed LS1 with LT's. Thats nice man. That is the only thing I had to get used to with my Cobra, quiet as a mouse. Until you punch it ofcourse.
Originally Posted by V-seriesTech
That is too busy.
Hows that Unit? Stock clutch should do fine.
