Street Racing & Kill Stories Basic Technical Questions & Advice
c5 z06 vs fbody
Old 12-08-2006, 03:45 PM
  #41
Torque_Wrench's Avatar
Danm Unit....lol..you're slacking or feeling merciful. You ain't locked the latest bench racing going on here...lol!
Torque_Wrench is offline
Old 12-08-2006, 06:06 PM
  #42
blackbird00's Avatar
Default video
i had a 2000 ws6 with full bolt ons and 4.10s i ran a buddies 01 Z06 he had a Varam and a xpipe we went from a 35 roll and were dead even till we shut down at about 140 i have a video of this also.
Click here to see Video
blackbird00 is offline
Old 12-08-2006, 06:08 PM
  #43
Ya the vid kinda sucks but you get the idea and dont mind the last part where i get **** stomped by that cobra he lied about his mods at first and told me after.
Old 12-09-2006, 01:31 AM
  #44
Mach1Mustang's Avatar
Trust me those damn ls6s pull very hard. I ran one on the street and he pulled my by a car untill around 120-125. Then he added a veraram and ran a 12.2 @ 117 in the 1/4!
Mach1Mustang is offline
Old 12-09-2006, 07:14 AM
  #45
Genesis_26317's Avatar
OKAY, OKAY!!!
Let the Bench Racing Expert come in!!!
You all sound like bickering ricers!!!
Okay I had 17k in my 1999 Z28. Mostly in suspension stuff, weight reduction, brakes, and chasis. Not a lot into engine work other than pretty much the best bolt-ons I could stick on the car that looked pretty.
My C5 vert A4 was completely stock.
Now my Z06 is completely stock.
Here goes C5<Z28<Z06.
The Z28 had big sticky tires, 3.23 gear ratio, a lot put into making it handle like a track car, and push like street/strip car. It whipped my C5 in speed and out handled it as well(mostly because I drove it for years and because and knew how to drive it).
If I could drive both the Z28 and the Z06 at the same time...
The Z06 would absolutely murder it.
Even considering the fact that I still frequently stall the manual transmission since I haven't used one in 7 years. That and the stutter that gets me all the looks when I don't actually stall it...
Hands down no questions. I mean honestly people, look at the two cars. Basically the Z06 is a C5 with bolt-ons added on at the factory.
Lower rear-end ratio, better gearing in the M12 transmission, wider/better tires, lighter weight wheels, lighter weight car, better exhaust (lighter weight too), heads and camshaft, intake, and MAF. Suspension isn't the topic here but it is worth noting.
I mean of course it can beat a bolt-on car it has all the upgrades bolt-on cars upgrade to. What work do you do on a Z06 that doesn't replace something that is already a upgrade over a regular C5?
*I'm not being an *** here and insulting any car I love F-bodies as much as any f-body owner
Genesis_26317 is offline
Old 12-09-2006, 09:40 AM
  #46
BRIAN98Z28's Avatar
Looks to me like you were getting pulled up top by that Z06, and that was an 01 you raced. 02+ is a stronger car.
BRIAN98Z28 is offline
Old 12-11-2006, 07:34 PM
  #47
scramblerman's Avatar
I raced a 01 Ws6 the other night. He has got a six speed with a 12 bolt and 4.10's. Motor wise this is most of his stuff. G5x3 cam, roller rockers, CM pushrods, dual valvesprings, LSx 90mm intake and Tb, pacesetter Lt's and ORYP, Borla cat back-running with it open, Lid w, K&N, and he has full weight. He may have few other little mods here and there. Anyways we raced from 55mph. I have a bone stock 02 Z06. We both started in third, we both didn't want to start in second-afraid of spinning. The first race was the best, we both took off at the same time, the other two I got a little jump and the other one he got a good jump. His car is so loud I only heard two honks, lol. Anyways the first race we both hooked and I started to pull, but only very slightly. He shifted into fourth while I still had about 1500 rpms left in the vette. When he shifted into fourth I then started to pull a bit more then I hit fourth and started to pull away faster. I shift into fourth around 100mph. So in the end we ended up going to about 120-130mph. Fourth gear is where I really start to gain on him or pull away, but only a little bit, not like a total murder. at the end of the run, he said that I started to pull away and he was at my rear tire. So it is a very close race, and he has lots of seat time with his short throw, even when he shifted he would not lose ground, me with the stock shifter adn I haven't had a manual car ever. His car when tuned put down over 400rwhp with those mods. I will be getting mine tuned next year possibly and see what it puts down along with the weight of the Z06. I have not ran it at the track yet, but he is running consistent low 12's, 12.1's with drag radials and dumping the clutch.
So this reply is not bench racing. These Z06's run hard especially from 5000rpms and up, they are monsters.
scramblerman is offline
Old 12-11-2006, 07:36 PM
  #48
I forgot, my hats off to that Ws6!!!!
Old 12-11-2006, 07:37 PM
  #49
i had heard from many people that you have to have around a 400rwhp f-body, that is full weight, to run with a stock Z06, 02-04.
Old 12-11-2006, 09:01 PM
  #50
hunterdawgs's Avatar
Originally Posted by BRIAN98Z28
Z06 weighs closer to 3100 pounds. I've even seen posts of owners weighing their cars and the resulting numbers were UNDER 3100 pounds!
My car with a quarter tank weighs under 3100 lbs.I might do a little weight redux but not much.No need to.
hunterdawgs is offline
Old 12-12-2006, 04:47 AM
  #51
There really isn't much you can do to reduce weight. At least that isn't a bit extreme, like pulling the passenger seat, sound proofing, or visors (or more extreme like the entire interior).
Either that or excessively pricey like a carbon hood for ~10 lbs or lightweight calipers, etc.
Old 12-12-2006, 05:18 PM
  #52
Brian98z28 yes beacsue i have 4.10gears so my car isnt that great up high at 140 if i had the 3.42s it would be different story. But it was dead even from 35mph till about 130 where he slightly pulled u guys get my point.
Old 12-12-2006, 05:19 PM
  #53
thank you scrambler man for teh props
Old 12-12-2006, 06:58 PM
  #54
V-seriesTech's Avatar
**repost ***
V-seriesTech is offline
Old 12-12-2006, 07:00 PM
  #55
Originally Posted by Jersey_TA
A Z06 will beat a stock F-body every time with equal drivers.
Noway dude. Sounds impossible to me. Got any proof of that?
Old 12-12-2006, 07:05 PM
  #56
You have a mid to high 11 second car bonestock.
Nice example.
Old 12-12-2006, 08:37 PM
  #57
Administrator
unit213's Avatar
unit213 is offline
Quick Reply: c5 z06 vs fbody
