700rwhp supra vs LT1
#303
#307
#308
#309
OH YAH!! well one time i had sex WITH A GIRL!!!
*edit*
but seriously, maybe one day a girl will go for a ride with me in my civic, it has a fresh swap and jdm coolant resivoir boot the spoon one was 60$ but i got the hookup on a mugen for only 50$
#311
#313
I guess i should make a real post before yall start thinking I'm really retarded
1994 camaro z28 hardtop--
arp high performance series rocker arm studs
comp cams pro magnum roller rocker arms 1.6 r
chromoly magnum pushrods
summit 58 mm throttlebody
4.10s
Comp cams valve springs (dual) With trick flow steel valve spring retainers +trickflow locks
summit electric water pump + wiring kit
Pacesetter full length ceramic coated race headers
pacesetter 3" o/r Y pipe
160* thermostat
egr block off kit
intake elbow
modified Opti (non vented to vented)
cc306 camshaft.
When i get some money together my next step is ported heads , nitrous, 255 lph fuel pump, mallory box and when the clutch goes out a new clutch
my end goal is 400 whp 4XX wtq off the bottle.
4.10s
160* thermostat
egr block off kit
intake elbow
cc306 camshaft.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://i47.photobucket.com/albums/f173/kenscivic/IMG_0917.jpg)
#314
Oh I understand prefectly. You always seem to equate your opinion as fact. None of my Supras sound like weedeaters.
#315
some fuel for the fire...
a supra that goes 7.9 on street tires...
http://www.youtube.com/watch?v=r4v0G_G_FN0
as people have stated before... its all in how the car is set up...
Why wouldnt use use 15 year newer tech ****? The new GT-R runs low 11's and destroyed the precious Z06 on the nurburing. Im sure if Toyota wanted to make a new supra they could achieve the same results.
Lets think logically for a second and compare apples to apples. How does a 1993 corvette stack up against a 1993 supra TT? Does it make more power? Handle better? Run quicker 1/4 mile times?
Very true...
Not so true...
WOW, the Nippon fanboy noobs are coming out of the woodwork now. Just like the roaches in their own homes.
Since you're sooo set on "factory based", why don't we go all the way to bone f'ing stock (as in C6Z06), right down to the shitty runflats. How many of your pure stock MKIVs are in the very low 11s/high 10s?? Don't give me the "10 years newer" tech **** either. If your Nippon wonders are sooo amazing they could kill this car, right fanboiee?? Not to mention what that same bone stock Z06 would do to your (stock) "epitome of perfection" on a road course.
Not so true...
#316
Wow, it did? Yeah those 4 seconds faster with the GT-R on cut slicks is crazy! What a car! I wouldn't say destroyed though, more like absolutely annihilated and humiliated!! Anyone know where I can get some Skyline posters to masterbate to? I already went to Hp Racing, they are all out.
#318
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
