Got called out, requesting some info
Umm no you didn't. Unless the dyno was about to break or some ****. I personally have never seen or heard an exhaust/tune/cai S197 go under 290rwhp except once on a MD known to show numbers that are way under.
I think you should be okay...granted I have never driven a stahled Camaro.
I have an 01WS6 with a lid,K&N,Loudmouh,smog legal headers, ORY, and some suspension and on street tires I take a local guy in an 05 GT A5 with every bolton you can imagine besides a blower.Hes got pulleys, stall,LTs,fulle exhaust, intake, just everything...and ofcourse was running his mouth and did the old looser fly-by after I worked that stang.
I am really dissapointed with the S197 tuners like Saleen and Roush and even the factory cars like the Shelby GT and GT500. IMO Turbo would be the only way to go, it seems like tuners like HP Performance are getting much bigger #'s at the same boost levels with turbo's.
If he has the mods that he says, intake, exhaust, and a stall, you will have a slight advantatge. It would guess that it would be pretty close though. What I would do in your case is make sure that you have all of the weight out of the car that you don't really need, and can remove easily. Spare tire/jack, 1/4 tank of gas, floor mats, maybe backseat, etc. If you haven't taken this stuff out yet it can make a slight difference from a full weight car, which could be the determining factor.
^^^^ Don't ever take off that cervinis kit that things sick and it sets your stang apart from all the regular everyday GTs. Looks awesome
No need to even bother removing all that **** unless you suck at driving. But you do have an A4 so i guess you're basically just steering
#33
Dyno #'s are relative to a lot of different factors (dyno, altitude, tire pressure, outside temp. ext.). I would say that 310 rwhp would be a more realistic expectation w/ those mods, but w/ the wrong conditions it is concievable that a gt that was a "runt" from the factory under less than ideal conditions could dyno that low. Example: My stock TA dynoed 278rwhp. 2 days later it was fully bolted (LTs, exhaust, induction, pulley, ext) and dynoed 332 rwhp under similar conditions. It was a dog from the factory, but once it could breath it was respectable. However, 275rwhp w/ a bolt on stang is pretty damn low (but not impossible).
#34
#35
[QUOTE=Super28Sport;8531206]^^^^ Don't ever take off that cervinis kit that things sick and it sets your stang apart from all the regular everyday GTs. Looks awesome
thanks alot man. i wont ever take it off. if i was worried about strictly go fast and weight i would be drivin a coupe or ls1 rx7.
#37
I was really close to buying a S197 GT because I got dealer pricing, but I was really discouraged by the aftermarket choices. And I could never do an STS kit, if I can't do front mount than I would wait until I could.
#38
Completely agree. In fact, I would say with those modifications an average car w/ normal conditions (even on a mustang dyno) would be minimum 300-310. The new generation GTs are a lot stouter than the they were in previous generations, but i think that the old stigma is still in alot of people's minds. Not to mention, this is a chevy forum and a lot of guys fall victim (myself included at times) to the idea that ford's power plant is inferior to GMs. I do have a lot more respect for ford's power plant after getting my *** handed to me by a GT (far from stock) the other day. I mean i used to think that you guy's needed a power adder to hang w/ an ls1, but from all apearences this guy was NA. Can someone fill me in on the differences between the two (new body style and old body style)? I too (for the most part) am ford iliterate!
#39
def. i love my front mount and would not change it if i could but for mods you just were not looking in the right places i guess. i would say there is about as much aftermarket for the 3v motors as there is for the ls2 motors or more.
#40
they have a 3v powerplant compared to a 2v which brethes 2x as good so respond to mods alot better espcially boost. your avg 2v stang will make around 240whp stock a 3v will make 275. but when you start modding you notice the biggedt diff. a bolt on 2v will be in the 270rwhp area a bolt-on 3v will be in the 320rwhp area. apply boost. and most of the 2v will max out around 420rwhp and hafta use 11+psi to get there. there are alotta 3v that will make 500rwhp with the same boost. but thats the short of it.
