Roush 427R
lmao, last time i read anything about these cars, car and river couldnt get one faster than a 13.2, so i dont know what magazine your reading, also i have raced a local one more than 3 different ocassions and i beat him in my stock ss every time., he gets outta the hole pretty good too
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
How do these guys justify asking someone to pay that much for a car that at the end of the day is still a Mustang. They aren't bad cars but over 50K they just aren't worth it. JMO.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Stock brakes, stock shocks, stock springs. And I would still not worry about an S281E on the track or roadcourse. Z06's are just to light, and considering mine accelerates quicker than a S281E I think it would be a rough day for the Mustang.
Do you know much about the S281E's? Stock suspension and you think you can handle it?...WOW.
I know about them pretty well, used to drive a Mustang and know the exact specs of that car. Rated@475 flywheel, dyno 420 or so, I am at 437 and weight like 500 pounds less. I have 13" Brakes stock, and 3220 RACEWEIGHT aint much weight to stop either. As far as the suspension they are not really comparable, unless they use the 99-04 IRS, but Im 99% sure it is just a strait axle 8.8 with maybe some adjustable suspension parts and good brakes.
They did use a solid axle, but if you think a solid setup can't be built to handle corners....you are soarly mistaken. Carrol Shelby himself has stated IRS isn't necessary given you can make a Solid rear handle just as well. It's all in knowledge of your setup.
An no offense, but 'used to drive a mustang' doesn't mean you know about all of them. Hell....I have owned seven mustangs in total, but I dont' know everything about stangs.
#32
Does have a SRA 8.8" and with 14" slotted and vented 4 piston front brakes.
#33
#34
For reference, the 05 S281E was rated at 500bhp and the 06+ were rated at 550bhp and 490?lb-ft.
#35
#38
Here is the fast list from Corvette Forum. There are 6 running 11.9's stock down to the tires.
C5 Z06 Bone-Stock Times
1--11.783 @ 116.90--1.818--J-Rod---------'02
2--11.818 @ 117.26--1.783--Ranger--------'02 11/03 Slip
3--11.844 @ 117.91--1.761--Gary2004Z06--'04 11/07 Post 229, Slip
4--11.93x @ 119.xx--1.xxx --Esoteric-------'0x
5--11.97x @ 118.80--1.90x--GMHTP--------'04 03/04
6--11.99x @ 117.61--1.xxx --02Z06Racer---'02
7--12.048 @ 115.92--1.866--pwrshfd-------'02 12/03
8--12.08x @ 115.95--1.83x--Pray ----------'02 01/06 Slip
9--12.09x @ xxx.xx --1.79x--UVETTA -------'03
10-12.205 @ 117.96--1.91x--Nat04Z06 -----'04
11-12.21x @ 112.xx--1.87x--Blue Angel----'02 07/04
12-12.227 @ 115.09--2.011--ZR WON -----'01 04/04 Post 6
13-12.22x @ xxx.xx --1.77x--holedgr-------'02
14-12.25x @ 117.xx--1.xxx --J Z06 --------'04 05/06
15-12.27x @ 115.16--1.957--SpeedFreak81-'03 07/07
16-12.2xx @ 1xx.xx --2.xxx --My1stZ ------'03
#40
