Turbo RSX-S
#62
***Repost Police***
It's fairly close, just like the hp/et calculator. But just like with the hp/et calculator, there are always exceptions, and always cars that do better/worse than expected.
Edit: Here's a pretty good example of what I'm saying...
http://www.honda-tech.com/zerothread?id=2248722
387whp on 10psi
400whp on 12psi
422whp on 14psi
And that's on a stock-interal motor. So if you know what you're doing, and pick the right turbo/housing/supporting mods, you can make FAR more than you're "supposed to."
387whp on 10psi
400whp on 12psi
422whp on 14psi
#63
387whp on 10psi
400whp on 12psi
422whp on 14psi
387whp on 10psi
400whp on 12psi
422whp on 14psi
#64
so, i'm really not sure why you're arguing with me.... You just admitted that that example that you're showing is probably an "exception to the rule".... Its making more power that they usually do....
So.... you don't know the gentleman that the OP raced.... so how can you assume that its also an "exception to the rule".... Its more likely, unless proven otherwise, that this guy would fall under the "general" case........ therefore not making over 400whp..... more like the Mid-300's ...
#65
What oh what would we EVER do without you!!!
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
But how do YOU ever learn about your precious imports (in order to 'learn' US) if you are ALWAYS on here doing your I.D.L. duties, and NOT on your myriad 'duh/import sites???????
Maybe you know it all already??
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#66
***Repost Police***
We all thank you so much oh high and holy one for 'edumacating' us dumb, ignorant, mulleted, rednecked, hillbilly *****, and keeping us in check regarding your fantabulous imports.
What oh what would we EVER do without you!!!![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Maybe you know it all already??![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#67
You can always block me if you want... some people on this site actually LIKE to learn about different cars other than the ones they own. If you're not one of them, so be it. You can stay in your little "my car is the fastest and best car in the world" little fog if you'd like.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Edit -
Exactly! Great post DD!
#68
***Repost Police***
Thats the thing, IF I CARE TO LEARN, I GO LOOK IT UP MYSELF AND RESEARCH. I don't need some **** **** douche preaching some bullshit to me. I also don't need some **** **** telling me what "COULD" have happened. I'm far from ignorant when it comes to MANY, MANY MANY platforms. So I'm very well aware of what is possible and what is bullshit. You on the other hand sound like a broken ******* record. ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#69
I can tell you I know a bit about a bit... never claimed to know it all, but I don't have my head in the sand UNWILLING to learn about anything other than what I drive. And SonOf, "most" people do crappy turbo setups, on EVERY car. If you know what you're doing, you can make really good power... on EVERY car. A ton of people have STS kits on their F-bodies, so should I base my judgement of turbo F-body performance on how the STS cars perform? It's all about how the boost is delivered. Remember the '03 Cobra test where they took off the Eaton M-112 and put on a good turbocharger and picked up 150rwhp from the SAME BOOST LEVEL?
Secondly, your point really doesn't get to the root of my question..... I understand that if you put a great turbo setup on the car that its going to make exceptional numbers... but my formula was for teh "general" case.... NO ONE ON THIS FORUM, INCLUDING YOU, knows anything about the guy the OP raced... so, imho, he falls into the "general" case.... therefore its very unlikely he was making the 400whp that you said he should be making - this is reserved for those that are the "exceptions" ....
i just don't get it... you're arguing that he's probably making 400+whp, when that's for those that have gone the extra mile to make sure they get every single hp outta their setup - whcih you've admitted that MOST people don't do..... so this guy is probably in this MAJORITY, and therefore isn't making anywhere near the power you claim him to be likely making
#70
And for the record - i've said it 1000 times i swear - i dont consider STS setups to be bad setups... Sure, judge an F-body on what an STS puts down.... most guys on STS setups have stock shortblocks... therefore they can't run the boost required to make numbers like the ones my car makes, or ones even more impressive....
If you go the route of forging the shortblock, putting good heads on, etc etc etc, an STS will make equally impressive numbers as a turbo setup like mine....
#71
First thing, i have no idea what Cobra you're talking about, but are you even able to tell me why it gained that much hp?? I know exactly why, but i really don't think you know much about boost from the sounds of it.... not being rude, but hardly anyone in this Street Racing forum knows much about boost from the posts i see....
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
#74
That's why I said "I doubt." It sounds like he was BSing about the claim of how much boost he was running, because to run that much boost he would either be running the stock internals on borrowed time, or running a forged-internal shortblock. In which case, why run only 15psi?
#75
Originally Posted by lilbuddy1587
1. Turbo is more efficient
2. cooler intake charge
3. no parasitic loss
4. The HEATON is an air pump, not a compressor like the turbo (so this actually refers back to # 1)
5. Idontrunelevens loves wiener
D. all the above.
D. all the above.
![Thatfunny](https://ls1tech.com/forums/images/smilies2/thatfunny.gif)
looks like something i'd see on the local forum among friends
#76
If you said a B16, or a B18 for that matter, I'd say sure..they can't expect much more than 375-400whp on 15psi even with the best setup, and largest practical turbo. But a K20 breaths oh so much better than the B and D series. They can make 400whp on 15, it would just have to be a good head porting and a great bottom end coupled w/ a turbo like a GT35R. It's not common though, in your defense.
#78
But I also will NOT rely on YOU as my source for that knowledge, regardless of how much you do or do not know.
I've never denied, or failed to acknowledge the power capabilities of properly; chosen/built/tuned/equipped import powerplants.
But YES, I most definitely WILL CALL
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
(i.e.; GTEs on stock internals pulling >1500 whp on pump gas, forever and reliably, no less.
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
#80
I am NOT "UNWILLING to learn about anything other than what I drive", as you say.
on the totally false, 'telephone game' import fanboieee deification **** when I hear it!!!
