killed a turbo probe
killed a fully built turbo probe
so last night i was meeting up with a friend from another forum and i saw this black turbo probe so i went ahead and called him out.we did 2 runs from 40 rolls.i ended up pulled him about 5-6 cars each run .he said his clutch was slipping and his tach wasnt working so ill take his word for it.after we raced he puched it from like 70 and i couldnt gain any ground on him till 120.so that car is pretty fast.
here is the list of his mods
Wiseco Pistons(.020 over, 8.5:1 comp), Pauter Rods, Wiseco Rings, Wiseco Wrist Pins, TOGA Rod & Main Bearings, TOGA HV Oil Pump, Brass Freeze Plugs, Fidanza Flywheel, Centerforce DF Clutch, Pacesetter STS(topped with a Sparco ****), Sparco E-Brake Handle, MSD Blaster 2 Coil, NGK V-Power Plugs, K&N Air Filter, HKS 2.25 I/C Piping w/FMIC, T3/T4 57 Trim Turbo (.63 A/R), 2.5" turbo-back exhaust(no cat), Energy Suspension Endlinks, 3-Pillar Pod w/Autometer Boost/Vac, Oil PSI, A/F Ratio Gauges
