Look at my New LCA
Old 11-01-2008, 06:16 PM
SanitysBane's Avatar
Dude I want a set, when it DKT going to start selling them?
Old 11-02-2008, 04:56 PM
UMI Performance's Avatar
Originally Posted by MeentSS02
So you guys are getting ready to offer something similar? That would be exactly what I am looking for...the only other thing currently available that I know of is offered by Hotpart.
Yes we have one being released any day now
This is much different then the Hotpart/J&M set-up... this is is adjustable, rebuildable and able to be tightened as the inside bushing wears. More info to be posted soon!
Ryan
Old 11-02-2008, 10:12 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Ryan
What about from a NVH standpoint? As quiet as poly over bumps? That's what I want...my car eats rod ends in about 1500-2000 miles (and by eats I mean it starts to rattle).
Old 11-02-2008, 11:17 PM
tpunk's Avatar
Judging from how they are made it should work out much better than a rod end for a DD. I can't wait to see what UMI has. I may swap out my stockers with moogs for those if the price is close to the rod end prices (maybe a bit less). I need to put in an order for your new PHB with Sam soon anyway.
Old 11-03-2008, 08:16 AM
Big Bird WS6's Avatar
Originally Posted by z28bryan
How well do they dampen noise?
nice and quite.
lee- yes they are a little over built. they were designed for a rock crawler. but mine with the aluminum arm is little then a stock arm. Lee how heavy is your boxed poly poly. and you new aluminum billet poly poly
now if you do like foxxtron said and put the rod end on the rear end. then it would even be lighter.
Dkt does not have them on the market yet. but you can pm me and email them to get about getting a discount set right now.
also as far as rebuilded able. they are easy. Curry makes a tool to rebuild the bushing. also if the joint isn't tight enough for you they have different size thinkness bushings to put in them
Old 11-03-2008, 08:42 AM
BMR Tech's Avatar
Originally Posted by Big Bird WS6
nice and quite.
Weight was not a factor when we designed either one of the boxed versions. I am assuming that is why you used aluminum was for the weight savings?
Old 11-03-2008, 09:14 AM
yes. and weight wasn't factor when dkt did this. it was about long lasting. but i know spohn and dkt boxed poly poly is around 6.5 and yours is little bigger. i was just wondering on your wieght.
Old 11-03-2008, 10:58 AM
BMR Tech's Avatar
The steel boxed are 7.2lbs. each I will have to check on the aluminum for you.
Old 11-03-2008, 11:17 AM
thank you.
Old 11-21-2008, 10:32 AM
first i have nothing against UMI. i believe they make great stuff
https://ls1tech.com/forums/new-produ...-rod-ends.html
^^ this is there new end links. isn't using one of these just like using an adjustable poly/poly tube?
nothing against your stuff. but them seem to be not as flexable as the ones i posted in the first post.
looking for other imput
Old 11-21-2008, 10:36 AM
No, those are not the new ones I was referring too... we have a new design coming out shortly
Old 11-21-2008, 10:39 AM
  #32
5301113's Avatar
interesting
Old 11-21-2008, 10:57 AM
  #33
LS1TECH Sponsor
Sam Strano's Avatar
You are mistaken if you think that's the new part that doesn't bind. That's simply a replacement setup to move from a rod-end to standard poly. There is a johnny-joint type end coming out soon.
__________________
Old 11-21-2008, 11:29 AM
  #34
MeentSS02's Avatar
Will the Johnny-joints rattle though over time? I'm basically waiting on this new part, but I really don't have enough information...it is either going to be these or the Hotpart poly-ball setup. I'm just tired of the rattle, especially after spending a week driving a new Vette and realizing how nice it was to ride in something that felt solid.
Old 11-21-2008, 12:50 PM
  #35
mine and others don't rattle. they are great. if you want to know more pm me
Old 11-21-2008, 02:58 PM
  #36
when you releasing?
Old 11-21-2008, 04:12 PM
  #37
z28bryan's Avatar
Rod ends don't really either depending on the type. It takes time for them to wear a bit. The right question to ask would be "do the johnny joints wear and rattle over time?"
Old 11-21-2008, 08:50 PM
  #38
MeentSS02's Avatar
...hence my question above. If they rattle over time, I don't think that'll be what I want. I have enough problems with rod ends rattling over time (like 1000-2000 miles), and that isn't acceptable to me.
Old 11-21-2008, 09:22 PM
  #39
Cumbias's Avatar
interesting. . . . . I tihink I would prefer theese over rod ends???
But I would like to know how long does it take for them to need to be rebuilt???
Old 11-21-2008, 11:32 PM
  #40
tpunk's Avatar
Shouldn't take to long to rebuild at all. I found a video somewhere about what it takes to rebuild them. I'm interested in the UMI LCA's when this comes out. I've been wanting something like this for a while.
Quick Reply: Look at my New LCA
