corvette brakes
The C6 brakes are larger then the C5 by 1" I believe... if you want to put them on your F-Body the same adapter brackets for installing the C5 will work just fine... but the C6 brakes do require a 18" rotor.
I pasted a link to a C5 install.. please take a look as it might be some help to you.
http://www.umiperformance.com/page.php?page=c5conv
Hope that helps!
Ryan
C5 caliper = C5 Z06 caliper (only difference is red powdercoat)
C6 caliper has bigger pistons than C5
C6 Z51 has yet bigger pistons than C6
C6 Z06 is completely different design as the rest (duh!)
The C5 conversion bracket will work for any of the calipers, but will only work with C5 rotors, 12.8". I am not aware of a bracket that will work for a larger rotor. reason for this is the bracket moves the caliper out far enough to fit the ~1" larger rotor.
also, the conversion SHOULD work with most 17" wheels.
BTW i have C5 z06 calipers, C5 rotors, and ll parts ready for install. I have the brackets ordered.
now, most C5 brake adaptor kits are designed to be used with an F-body abutment bracket. those two pieces combined will limit you to a 12.8" rotor.
NOW, the other part to look at is the caliper. the F-body caliper, as well as all C5 and C6 (standard, z51 and z06) all have the same bolt pattern. this is what allows you to use whichever caliper you want of those that are listed. none of that will change the rotor size.
NOW, you cant use C5 or C6 abutment brackets with any of the adaptor kits that ive seen.
i hope that helps.
just make it easy, get C5 Z06 calipers, braided lines, and C5 rotors (drilled and slotted). unless its a track car this setup will be great. my install is waiting on my adaptor kit.
Base C5/C5 Z06/Base C6/C6 Z51 all use the same caliper. The C6 casting is a bit stronger, but the pistons and mounting ears the THE SAME.
Base C5/C5 Z06/Base C6 use the same 12.8" rotor and fit under 17" wheels.
C6 Z51 use 13.4" rotor that fit under 18" wheels. You can use Z51 rotors by swapping to the Z51 caliper bracket.
how do you propose you use a z51 "caliper bracket" on an fbody? ive never seen an adaptor kit that uses corvette abutment brackets.
I didnt know that the pistons were the same size, i was told that they were different.
other vehicles with similar calipers are XLR, TBSS and the 5.3L impala and GP. the impala and GP ones though are slightly smaller, they use a thinner rotor.
I noticed you forgot to buy these http://www.umiperformance.com/12455799?category_id=117
and yes, from my research the C6 Z06 caliper will bolt up as the "ears" are the same distance apart as the other C5 and C6 calipers.
