corvette brakes
theres two routes to take.
1) using Fbody abutment brackets and pads
-LG style C5 conversion brackets (PM me if you want info on a cheaper but similar one)
-C5 or c6 caliper of choice
-C5 Rotor (plain faced or drilled or slotted)
-C5 anti squeel clips (caliper part)
-Fbody anti squeel clips (pad ends)
-Fbody
-Fbody pads
-Fbody braided lines (optional)
2) Corvette abutment brackets with Corvette pads.
-UMI or BMR style C5 conversion brackets
-Matching C5 or C6 abutment brackets
--C5 anti squeel clips (both caliper and pad ends)
-Matching Corvette pads
Type 1 is better because pads will be cheaper (generally) and if you get the calipers directly from GM the abutment bracket is additional, so more cost. Also, you dont have to cut the knuckle, so it can be returned to stock when you sell the car or upgrade later.
Type 2 is better because you can get the Z51 rotor in there (bigger) and there MIGHT be more performance options for Corvettes in the brake pad world.
-Fbody
-Fbody pads
Meh, it's not that bad to cut. The ones on my car have been on there for years with no issues. As long as quality pads and rotors are used they last quite a while. I don't remember the pads or rotors being much more than F-body parts either... but it's been a while and this wasn't my car back when we put new pads and rotors on.
Seems like some folks got a tight wallet.
I DON'T MEAN TO STEAL THIS THREAD. i just purchased a set of C5 brakes, Calipers and Rotors. Where can I find the Bracket needed to mount these without haveing to cut anything? I want a high quality bracket.
#33
LG at least use to make a set that used the F-body abutment bracket. Not sure if they still do, they dropped a lot of their F-body products. Otherwise UMI makes a good set if you can bring yourself to cut the spindle. Their isn't really an adverse effect that I notice from cutting them. Like I said these have been on this car since about 04/05 and still no problems.
#34
theres a guy on ebay that sells the LG style ones. his screen name is 1976LS1 or something like that. send him a message and make sure you are getting the right now. he has great customer service.
#35
I've been looking for the "lg" brackets but can't find them anywhere, not even on the lg website. I may just go with umi and cut the ears off.
My biggest question now is, what needs to be done to the rear to mount the rear calipers or do i need to do anything?
#36
theres not much needed to be done to the rears. i hear that the corvette rears bolt right up, but they arent much better than stock, so it would be wasted money.
IM PMing you a link to an auction for an "LG style" bracket.
#39
For the rear I ended up just using the C5 calipers and pads but not the C5 pad abutment bracket (PAB) or the C5 rotor (that has the directional vanes for better cooling). The problem was that the e-brake is set up a little differently and hence the Fbody rear rotors are a little taller than the C5. The C5 rotors only covered up about half of the e-brake pad. I talked to a guy at KORE3 and he said that they had researched several options for a conversion kit for the rears but nothing was very practical. You can run the C5 calipers and pads with the Fbody PAB very easily though, just swap them out.
